【Linux】
How can i add LVDS display to my minimal Linux OS build for rk3568jq using Yocto
Posted at 4/19/2023 16:05:00
Type:
Self-Compiled Firmware
SDK Package Name:
rk356x_linux_release_v1.3.0b_20221213
Last Commit:
0000-00-00 00:00:00
Modification Content:
LVDS configuration
Log:
no log (2).zip
I have a custom board based on RK3568jq.
I made Linux minimal image using Yocto:
https://wiki.t-firefly.com/en/Fi ... e/manual_yocto.html
Everything works fine, but current configuration is HDMI.
I have a question:
How can i add LVDS display to my minimal Linux OS build for rk3568jq using Yocto system ?
What dts file should i change and how ?
I did it before but not for Yocto, i used stardard FireFly compile Linux firmware system:
https://wiki.t-firefly.com/en/iCore-3568JQ/linux_compile.html
- sudo ./build.sh itx-3568q-lvds-ubuntu.mk
- sudo ./build.sh
Copy the code
I made changes in file
/rk356x_linux_release_20211019/kernel/arch/arm64/boot/dts/rockchip/rk3568j-firefly-itxq-lvds_m10r800.dts
- lvds_panel: lvds-panel {
- compatible = "simple-panel";
- status = "<b>okay</b>";
- enable-gpios = <&pca9555 PCA_IO1_2 GPIO_ACTIVE_HIGH>;
- backlight = <&backlight>;
- enable-delay-ms = <35>;
- prepare-delay-ms = <6>;
- unprepare-delay-ms = <0>;
- disable-delay-ms = <20>;
- bus-format = <MEDIA_BUS_FMT_RGB888_1X7X4_SPWG>;
- display-timings {
- native-mode = <&timing0>;
- timing0: timing0 {
- clock-frequency = <71098000>;
- hactive = <1280>;
- vactive = <800>;
- hfront-porch = <40>;
- hsync-len = <80>;
- hback-porch = <40>;
- vfront-porch = <3>;
- vsync-len = <10>;
- vback-porch = <10>;
- hsync-active = <0>;
- vsync-active = <0>;
- de-active = <0>;
- pixelclk-active = <0>;
Copy the code
