[General] Device does not start in normal mode, need debug console
75
【General】 Device does not start in normal mode, need debug console
Posted at 7/6/2023 04:12:07      View:783 | Replies:2        Print      Only Author   [Copy Link] 1#
  • Type: Self-Compiled Firmware
  • SDK Package Name: ??
  • Last Commit: 0000-00-00 00:00:00
  • Modification Content: ??
  • Log: log.zip
I am starting with this device, and compiled the image for it.
Flahsed the device, and now it does not start in normal mode. It turns LAN1 leds on, then in 3 seconds off, then on again and so on.
Is there any way to have diagnostic console where I can see all the output starting U-boot? And potentially can see where boot fails?
Thanks.
log.zip
155 Bytes, Down times: 0
administrator
Rank: 9Rank: 9Rank: 9
Posted at 7/6/2023 09:31:24        Only Author  2#
Hello, which kind of device or board do you use? And firmware?
Posted at 7/6/2023 19:30:02        Only Author  3#
iHC-3308GW, openwrt build (I guess originally from here - https://gitlab.com/TeeFirefly/rk3308-linux).
Edit: it is NOT openwrt! It is buildroot.
Is there any open source openwrt for 3308GW? This one https://dev.t-firefly.com/thread-104203-1-1.html is a firmware, not a source code.
