[Linux] RK3566 Uart3 Noise or Meaningless Data Issue
65
【Linux】 RK3566 Uart3 Noise or Meaningless Data Issue
Posted at 7/25/2023 00:49:55      View:768 | Replies:1        Print      Only Author   [Copy Link] 1#
  • Type: Self-Compiled Firmware
  • SDK Package Name: ROC-RK3566-PC_Rk356x_v1.3.2f_230724.img
  • Last Commit: 0000-00-00 00:00:00
  • Modification Content: &uart3 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&uart3m1_xfer>; }; status set to "okay"
  • Log: test.zip
Hi, We have ROC-RK3566-PC-V1.2
We want to use uart3.
For this reason I applied the following steps.
Step 1: I compiled your ubuntu 18.04 sdk and booted  on our device.
Step 2: I enabled uart3 in k356x_linux_release_v1.3.0b_20221213/kernel/arch/arm64/boot/dts/rockchip/rk3568-firefly-port.dtsi like following line
&uart3 {
        status = "okay";
I set status set to "okay"
Step 4: Recompile and update image on device
Step 5: Setup the serial settings with stty with command on the following line
- stty -F /dev/ttyS3 ospeed 115200 ispeed 115200 cs8
- stty -F /dev/ttyS3 raw
Now, I can see the /dev/ttyS3 serial point  but I have some problems to communication with ttyS3
I am constantly getting data that looks like meaningless or noise.
This dataset looking like that: b2 b2 f6 f6 90 b2 b2 f6 f6 90 b2 b2 f6 f6 90 b2 b2 f6 f6 90
and this data repeating always
On the ROC-RK3566-PC Specification pdf the uart3 sharing pin with AUDIOPWM
May be it is our problem.
How can I fix this problem ?
Is our method of the enabling UART3 correct ?
test.zip
154 Bytes, Down times: 0
Posted at 7/25/2023 04:20:08        Only Author  2#
I solve my problem.
The original dtsi file looking like this
  1. &uart3 {
  2.         status = "okay";
  3.         pinctrl-names = "default";
  4.         pinctrl-0 = <&uart3m1_xfer>;
  5. };
Copy the code
I applied that
  1. &uart3 {
  2.         status = "okay";
  3. };
  4. (delete the pinctrl-0 and pinctrl-names)
Copy the code
