Panoramic Stitching
Posted at 8/14/2023 22:41:29
Hi,
I just read your article https://en.t-firefly.com/doc/case/info/id/544.html on panoramic stitching based on rk3588
Now, I have several questions regarding this topic
1) Is the solution only available from your boards or is it generic to any rk3588 board?
2) The article speaks about 6 cameras, but I would be interested in just 2 configuration, side by side creating a ultra panoramic view
3) I have researched this topic quite a bit, and seems it needs hardware synchronizing in the cameras themselves to work properly. Does your arrangement use them?
4) Do you have 4K 60fps cameras that can be used instead (as said, in a paired configuration)
5) Is this solution available for Linux? It is key to have hardware accelerated decoding and encoding, as well as hardware stitching, so don't know if it runs in Linux, and in what particular Linux version
My goal is to build an ultra panoramic camera with 180º HFOV and based on some AI based logic, crop the resulting image into FullHD final stream.
I have looked into Nvidia based solutions, but the alternatives I have found on the camera side are quite expensive and require quite a powerful Nvidia board, making the project unfeasible (multi camera systems from e-con). I'm also aware of Cupola360 but seems they only work in huge volumes.
My project is very price sensitive (if not, would do it with a Nvidia based alternative), but seems something based on rk3588 could potentially be much cheaper.
Thank you very much. Kind regards
