[Linux] What is the exact sequence of boot process when I boot the device for the 1st ti
91
【Linux】 What is the exact sequence of boot process when I boot the device for the 1st ti
Posted at 9/14/2023 21:46:57      View:712 | Replies:1        Print      Only Author   [Copy Link] 1#
1. What is the exact sequence of boot process when I boot the device for the 1st time after flashing the eMMC? I. e., which partition is the device booted from, what is done at the various stages and so on...
2. I want to make a bootable SD card image, which shall flash u-boot, boot and rootfs partitions from images stored on that SD card. Can I modify the recover partition to perform the task?
bootlog1st.txt.gz
45.15 KB, Down times: 0
administrator
Rank: 9Rank: 9Rank: 9
Posted at 9/16/2023 09:49:50        Only Author  2#
Please check this wiki instructions: https://wiki.t-firefly.com/en/iCore-3568JQ/index.html
