[Linux] WiFi mode on ROC-RK3566-PC (AP6256)
15
【Linux】 WiFi mode on ROC-RK3566-PC (AP6256)
Posted at 12/22/2023 16:47:07      View:403 | Replies:0        Print      Only Author   [Copy Link] 1#
I flashed my device ROC-RK3566-PC by firmware:
ROC-RK3566-PC_Ubuntu20.04-r2409_v1.3.2f_230717.7z
Downloaded it from here:
https://drive.google.com/drive/folders/1eUdiafTCR6CsS9Nt7F5Mhx6lJ_f0MVmo
I tried to switch Wi-Fi to "monitor" mode:
  1. sudo airmon-ng start wlan0
Copy the code
or
  1. sudo iwconfig wlan0 monitor mode
Copy the code
But the operation fails with an error:
An ERROR occurred when adding the monitoring mode interface: the command was not executed: The operation is not supported (-95)
It seems that the driver does not support this mode of operation. Can this be fixed?
null.zip
4 Bytes, Down times: 0
