[Hardware] RK-3566-PC EMMC Root Partition gets corrupted frequently
65
【Hardware】 RK-3566-PC EMMC Root Partition gets corrupted frequently
Posted at 2/5/2024 23:11:21      View:302 | Replies:1        Print      Only Author   [Copy Link] 1#
  • Type: Self-Compiled Firmware
  • SDK Package Name: ROC-RK3566-PC-MIPI_Rk356x_v1.3.2f_240202.img
  • Last Commit: 0000-00-00 00:00:00
  • Modification Content: no modification
  • Log: log.zip
At random times, ubuntu 20.04 running on emmc breaks. The /boot partition becomes completely empty and all /usr/bin applications become inaccessible.
For example
root@aquadata:~# ls
-bash: /usr/bin/ls: No such file or directory
Even the basic linux application "ls" cannot be used. After this happens, the device does not boot at all on reboot. The only way to reboot is to use SD-boot or rewrite emmc with RkDevTool. I can't understand why.
I think it is a power problem or an automatic update problem.
I am using a 5v 2.4A adapter.
I have about 30 RK-3566-PCs and this problem is happening with all of them, no matter if they are Offical Image or Custom Image.
Can you help me with this ?
log.zip
785 Bytes, Down times: 2
Posted at 2/19/2024 16:57:30        Only Author  2#
There has never been such a situation as you mentioned before
1 Because this situation would not have occurred if EMMC had not been erased, could you recall what special actions were taken before this issue occurred?
2 Provide complete boot logs
3 Provide corresponding version information based on Wikipedia
https://wiki.t-firefly.com/en/Fi ... version-information
