[Linux] Problems building Linux kernel with RT patch PREEMPT_RT
19
【Linux】 Problems building Linux kernel with RT patch PREEMPT_RT
Posted at 4/11/2024 13:48:45      View:333 | Replies:0        Print      Only Author   [Copy Link] 1#
Hello.
When building the Linux kernel with the RT patch PREEMPT_RT 5.10.198, the errors below appear. Please tell me what needs to be done to correct them.
   AS      .tmp_vmlinux.kallsyms2.S
  LD      vmlinux
  BTFIDS  vmlinux
  SORTTAB vmlinux
  SYSMAP  System.map
  OBJCOPY arch/arm64/boot/Image
  MODPOST modules-only.symvers
  LZ4C    arch/arm64/boot/Image.lz4
drivers/mmc/core/.mmc_blk_data.cmd: No such file or directory
make[2]: *** [scripts/Makefile.modpost:168: modules-only.symvers] Ошибка 1
make[1]: *** [Makefile:1856: modules] Ошибка 2
make: *** [arch/arm64/Makefile:214: rk3568-firefly-itx-3568q.img] Error 2
make: Leaving directory '/home/andy/PROJECTS_RT/rk356x_linux5.10_release/kernel'
ERROR: Running /home/andy/PROJECTS_RT/rk356x_linux5.10_release/device/rockchip/common/build-hooks/10-kernel.sh - run_command failed!
ERROR: exit code 2 from line 36:
ERROR: call stack:
    build-helper: run_command(36)
    10-kernel.sh: do_build(61)
    10-kernel.sh: build_hook(209)
    build-helper: try_func(63)
SDK name:  rk356x_linux5.10_bsp_release_20240319_v1.4.0b
Configuration kernel in   logs_and_configForKernel.tar.gz
The following errors that occurred when building the kernel have been fixed:
ERROR:
security/smack/smack_lsm.c:54:21: warning: 'smack_ipv6_lock' defined but not used [-Wunused-variable]
error, forbidden warning:smack_lsm.c:54
   54 | static DEFINE_MUTEX(smack_ipv6_lock);
FOR CORRECTION:
    #ifdef SMACK_IPV6_PORT_LABELING
    #endif
ERROR:
drivers/usb/dwc2/platform.c: In function 'dwc2_resume':
drivers/usb/dwc2/platform.c:816:12: error: 'struct dwc2_hsotg' has no member named 'driver'
  816 |   if (!dwc2->driver)
make[4]: *** [scripts/Makefile.build:273: drivers/usb/dwc2/platform.o] Ошибка 1
make[3]: *** [scripts/Makefile.build:516: drivers/usb/dwc2] Ошибка 2
make[2]: *** [scripts/Makefile.build:516: drivers/usb] Ошибка 2
make[2]: *** Ожидание завершения заданий…
FOR CORRECTION:  (file   .config)
  <M>   DesignWare USB2 DRD Core Support
  затем выбрать
           DWC2 Mode Selection (Dual Role mode)  --->
ERROR:
rivers/rpmsg/virtio_rpmsg_bus.c:194:3: error: 'const struct rpmsg_endpoint_ops' has no member named 'get_mtu'
  194 |  .get_mtu = virtio_rpmsg_get_mtu,
drivers/rpmsg/virtio_rpmsg_bus.c:194:13: error: initialization of '__poll_t (*)(struct rpmsg_endpoint *, struct file *, poll_table *)' {aka 'unsigned int (*)(struct rpmsg_endpoint *, struct file *, struct poll_table_struct *)'} from incompatible pointer type 'ssize_t (*)(struct rpmsg_endpoint *)' {aka 'long int (*)(struct rpmsg_endpoint *)'} [-Werror=incompatible-pointer-types]
drivers/rpmsg/virtio_rpmsg_bus.c:194:13: note: (near initialization for 'virtio_endpoint_ops.poll')
cc1: some warnings being treated as errors
make[3]: *** [scripts/Makefile.build:273: drivers/rpmsg/virtio_rpmsg_bus.o] Ошибка 1
make[2]: *** [scripts/Makefile.build:516: drivers/rpmsg] Ошибка 2
FOR CORRECTION:
    .trysend_offchannel = virtio_rpmsg_trysend_offchannel,
#ifdef CONFIG_NO_GKI
#endif
ERROR:
drivers/rpmsg/virtio_rpmsg_bus.c:712:16: warning: 'virtio_rpmsg_get_mtu' defined but not used [-Wunused-function]
error, forbidden warning:virtio_rpmsg_bus.c:712
  712 | static ssize_t virtio_rpmsg_get_mtu(struct rpmsg_endpoint *ept)
FOR CORRECTION:
static ssize_t virtio_rpmsg_get_mtu(struct rpmsg_endpoint *ept);
#endif
    struct rpmsg_device *rpdev = ept->rpdev;
    struct virtio_rpmsg_channel *vch = to_virtio_rpmsg_channel(rpdev);
    return vch->vrp->buf_size - sizeof(struct rpmsg_hdr);
#endif
Log_files.tar.gz
67.29 KB, Down times: 0
266.51 KB, Down times: 0
