Display LCD which with double LVDS interface type
2
Posted at 12/4/2014 14:20:28      View5398 | Replies3        Print      Only Author   [Copy Link] 1#
Finally got the engineer model of RK3288, feeling nice at the first sight. Because the development board leaves interfaces only for LCD data cable, I have added a interface board to support dual LVDS output.
As LVDS requires complete reference surface with strict layout, the length error between signal traces in a pair must be less than 30mil and the length error between signal pairs must be less than 100mil. Whats more, the corners should adopt arc or obtuse angel and the impedance requires Z=100ohm10ohm.
With a little help from Firefly team, I managed to figure out the excellent layout. Heres the outcome. It is a 10.1 inch screen with 1200*1920 dpi.
[size=0.83em]
Posted at 12/5/2014 17:04:47        Only Author  2#
Uploader rk3288_display_v11.pdf
Posted at 1/11/2016 23:09:06        Only Author  3#
Hi Developer_X,
Could you give more details how you connected two LVDS LCDs to Firefly? Is it in this PDF document from your second post? If so, then I can't download it.
Regards
Wolf
Posted at 3/11/2026 03:55:42        Only Author  4#
Im amazed by this article, thank you for sharing it. Free Valid NCP-MCA test guide exam papers for you to download. Best of luck in your exams!
