Questions about the 8ch I2S/PCM RK3288 peripheral
638
Posted at 4/13/2015 21:32:06      View:5405 | Replies:4        Print      Only Author   [Copy Link] 1#
Hello,
I have some questions regarding the 8ch I2s/PCM peripheral inside the RK3288 SoC (chapter 16 of the manual).
Q1: looking at the timing diagrams starting on page 752 (sections 16.3.1 to 16.3.7), it seems that I2S allows 1 stereo channel only per output, while the DSP/PCM mode allows from 1 to 4 stereo channels on a single output (SDO0). Is it right?
Q2: the peripheral control registers list shows only 1 transmit fifo data register (I2S_TXDR on page 765). How is this unique TX data register connected to the 4 TX FIFOs?
Q3: for that matter what I understand is that the I2S_TXCR::CSR field (page 756) sets the number of stereo channels AND the number of used TX FIFOs. In PCM mode the n FIFOS can be seen as a single FIFO with a depth equal to 32 x n. Is it right?
Q4: in I2S mode, each FIFO is routed to the corresponding I2S_SDOx output. Is it right?
Q5: from the ES8323 codec data sheet it seems that this codec manages only a single stereo stream, wether configured as an I2S or a PCM device. So this would mean that it is not possible to send more than 2 channels when using the firefly board as is. Is it right?
Thanks.
Posted at 1/9/2026 23:12:22        Only Author  2#
Your article was incredibly refreshing, thank you. The Reliable free 300-540 study guide helped me secure a promotion and salary raise. Now it’s free to all. Best wishes for your career advancements!
Posted at 1/11/2026 05:37:38        Only Author  3#
Perfect content, I’m clicking like immediately. Best of luck on your exam! Here’s the free C1 exam question content.
Posted at 1/13/2026 01:17:03        Only Author  4#
Thank you for your article, it was a true eye-opener. The Demo PDI test questions were key in securing my promotion and raise—now it’s your turn! Get them for free!
Posted at 1/19/2026 23:03:26        Only Author  5#
PDFExamDumps不僅為你提供優秀的資料,而且還為你提供優質的服務。如果你購買了PDFExamDumps的考古題,PDFExamDumps將為你提供一年的免費更新。這樣你就可以一直擁有最新的AZ-500試題資料。而且,萬一你用了AZ-500考古題以後,考試還是失敗的話,PDFExamDumps保證全額退款。這樣一來,你還擔心什麼呢?PDFExamDumps對自己的資料有足夠的信心,你也要對PDFExamDumps有足夠的信心。為了你的考試能夠成功,千萬不要錯過PDFExamDumps這個網站。因為如果錯過了它,你就等於錯失了一次成功的機會。
