Cannot Flash Boot Image, nor boot from eMMC
7
Posted at 4/29/2015 05:46:39      View:6916 | Replies:5        Print      Only Author   [Copy Link] 1#
Hello,
I managed to brick my Firefly RK3288. Whatever I do (erase flash, low level format, try to update with other images), I cannot seem to get it to boot into anything.
The only thing that works now is Ian Morrison's instructions on how to make a bootable SD card: https://plus.google.com/+IanMORRISON/posts/22Vxc6Sr5Ei
However, I do not get to load the OS from the card, what happens is that when SD card is inside, the system uses it's boot image to load the OS on eMMC (not on the SD card).
So - is there a way to re-flash the boot (or everything) back into the eMMC so that it can start up without SD card?
Thanks!
Posted at 4/29/2015 11:50:06        Only Author  2#
The error I get when trying to load the boot image is:
Loading loader...
Support Type:RK320A        Loader ver:2.17        Loader Time:2014-11-26 09:28:49
Prepare IDB Fail
I tried getting into MaskROM mode and even when I jump the test point with the capacitor, all I get is the "Loader" mode. Never MaskROM.
Any help would be greatly appreciated.
Thanks!
Posted at 4/29/2015 14:48:14        Only Author  3#
The last time I saw Prepare IDB Fail was the SD inserted when I execute the upgrade_tool.
Posted at 4/29/2015 15:20:21        Only Author  4#
How did you know the OS is loaded from eMMC when SD card is inserted?
When a bootable SD card is inserted, Firefly will boot from SD card(i.e load related images from SD card).
Posted at 1/10/2026 01:10:28        Only Author  5#
This article is remarkable, thank you for sharing it with me. I used the 500-560 test dumps.zip to get promoted and earn more. Now, it’s available for free. Best of luck with your career!
Posted at 1/15/2026 19:39:02        Only Author  6#
あなたは自分の役職で長年働いてきましたが、昇進していませんか?それとも、新しい社内のコーナーと自分が顕著なようにするために熱望していますか? Salesforce-MuleSoft-Developer-I試験の資料が役立ちます。当社Salesforceの製品で数日間勉強して練習した後、Salesforce-MuleSoft-Developer-I試験に簡単に合格します。神は自ら助ける者を助く。私たちの教材を選ぶと、あなたのそばに神が見つかるでしょう。あなたがしなければならない唯一のことは、あなたの選択をして、私たちのSalesforce-MuleSoft-Developer-I試験問題を勉強することです。とても簡単ではないですか?だから、今すぐSalesforce-MuleSoft-Developer-I学習Salesforce Certified MuleSoft Developer (Mule-Dev-201)ガイドについてもっと知りましょう!
