CPU temperature fanless
10
Posted at 6/19/2015 13:23:25      View:5744 | Replies:9        Print      Only Author   [Copy Link] 1#
Hi, is it possible to run the Firefly Rk3288 without the cooling fan, only with the heatsink? Does it overheat when the CPU comes to high usage (e.g. playing 4k videos or playing games)?
Thanks for your answers.
Posted at 6/20/2015 06:37:18        Only Author  2#
larditi:
Have found that one will be safe for anything, for the chip is thermally protected.  I ran my Firefly with an oc'ed kernel with just a heatsink on the cpu.  Abused it and never saw any thing above 60-C, with the fan added it never went above 45-C abused.  There are several apps available from google play which will allow a real time temperature overlay on screen.  Have fun, the temp overlay is something which you may want, if extreme gaming with an extreme oc, for the extra piece of mind.
----cappybob
Posted at 6/28/2015 13:33:20        Only Author  3#
cappybob Posted at 6/20/2015 06:37
larditi:
Have found that one will be safe for anything, for the chip is thermally protected.  I r ...
what kind of heatsink are you using and are you using the acryllic case or an enclosure?
Posted at 6/28/2015 23:14:05        Only Author  4#
e97 Posted at 6/28/2015 13:33
I found an old south bridge mother board and cut my own to fit the acrylic case.  Used a safe heat transferring tape to affix.  Firefly board under acrylic top spaced with SSD attached on bottom acrylic.
later--cappybob
Posted at 10/22/2025 15:28:35        Only Author  5#
To chápu, technologie a hardware mohou být složité, i když já si občas hledám relax úplně jinak. Nedávno jsem po dlouhém dni narazil na capospin casino. Ze začátku jsem pár kol prohrál, ale pak jsem odvážně zvýšil sázku a nakonec vyhrál pěknou částku, která mě opravdu potěšila. Hráči z České republiky tam mají speciální bonusy, takže se tam rád vracím, když chci zkusit štěstí, pobavit se u online her a odpočinout si od technických problémů a diskusí o přehřívání zařízení.
Posted at 1/8/2026 17:51:09        Only Author  6#
This article is simply breathtaking, thank you for sharing it with us! Good luck on your exams! Free Latest C-S4CPB-2502 test voucher exam papers are now available.
Posted at 1/17/2026 02:31:47        Only Author  7#
This article is truly a valuable source of knowledge, and I’ve benefited a lot. New test camp SIE free questions are essential for your career success—get them for free!
Posted at 1/30/2026 11:16:27        Only Author  8#
Your article made such an impression on me, I’m deeply appreciative. These Reliable study questions CIPT ebook questions helped me climb the career ladder and increase my earnings, and now I’m sharing them with you for free!
Posted at 2/8/2026 23:15:48        Only Author  9#
一部のお客様は時間を無駄にしないホワイトカラーの従業員であり、プロモーションを得るために早急にSalesforce認定を必要としますが、他のお客様はスキルの向上を目指している場合があります。そのため、AP-209の質問と回答の異なるバージョンを設定することにより、異なる要件を満たすようにします。特別なものは、オンラインのAP-209エンジンバージョンです。オンラインツールとして、便利で簡単に学習でき、Windows、Mac、Android、iOSなどを含むすべてのWebブラウザとシステムをサポートします。このバージョンのAP-209試験問題をすべての電子デバイスに適用できます。
Posted at 2/19/2026 15:34:18        Only Author  10#
Your article was so insightful, I’ll carry it with me. The AB-730 cost effective dumps test questions are now available for free—your career success is just a step away!
