New Topic
OV13850 use with Linux
46
Posted at 6/24/2015 22:33:27      View10614 | Replies12        Print      Only Author   [Copy Link] 1#
I can use the OV13850 module fine in Android, but when in Lubuntu, it does not show up. Does anyone know of a good solution to this problem?
Thanks
Posted at 7/7/2015 00:13:32        Only Author  recommend
macdam Posted at 7/4/2015 19:22
Hi
I have the same need and the same problem did you find any suitable driver?
Still looking around online
vip
Rank: 6Rank: 6
Posted at 6/25/2015 13:12:41        Only Author  2#
OV13850 don't support in ubuntu, need isp driver, but it does not open source by vendor soc.
Posted at 6/29/2015 22:36:55        Only Author  3#
How could I get this isp driver?
vip
Rank: 6Rank: 6
Posted at 7/1/2015 17:36:29        Only Author  4#
you can contact to rockchip, but I think it will say not open also.
Rank: 8Rank: 8
Posted at 7/4/2015 19:22:31        Only Author  5#
Hi
Posted at 6/2/2016 20:08:56        Only Author  7#
Hi,
I also need to use ov13850 sensor on linux side but I can't found any driver. Is available any suitable driver? Is there any rockchip git repository where I can find it?
thank you,
regards
Andrea
Posted at 12/1/2025 14:03:18        Only Author  8#
I wonder if it's actually easy to set up though. Maybe this forum can help me avoid brain drain when doing "moca test" - sorry "camera test" on Linux next time.
Posted at 1/10/2026 06:37:52        Only Author  9#
Truly an impressive article, Im grateful for your share. Valid H19-619_V1.0 exam guide materials test questions are now free. Good luck with your exams!
Posted at 1/10/2026 06:43:31        Only Author  10#
I feel so inspired after reading this article, thank you for the share! Improve your IT skills and grab the free New NCM-MCI-6.10 test topics. Best of luck with everything!
Return to List
12
