Release of Dual OS Firmware for FirePrime Mass Produced Board with Touch Screen
403
Posted at 7/20/2015 17:40:41      View:2415 | Replies:1        Print      Only Author   [Copy Link] 1#
Hi folks,
A new dual OS firmware for FirePrime mass produced board has been released. It comes with touch screen support!
You can download it at Google Drive:
   https://drive.google.com/file/d/ ... 2M/view?usp=sharing
Here're the snapshots:
Posted at 7/20/2015 17:48:08        Only Author  2#
1 Add touch screen support to FirePrime Linux
1.1 Introduction
  X11 window system uses evdev input driver to handle touch screen
  events. There're mainly two steps to add touch screen support:
  1. Add X11 configuration file to use evdev driver for touch screen.
  2. Make evdev support touch screen (also emulate right mouse button).
1.2 Configuration
  Create file `/etc/X11/xorg.conf.d/10-evdev-gslX680.conf' with
  following contents:
  | Section "InputClass"
  |         Identifier "gslX680 evdev touchscreen"
  |         MatchProduct    "gslX680"
  |         MatchDevicePath "/dev/input/event*"
  |         Option "EmulateThirdButton" "true"
  |         Option "EmulateThirdButtonTimeout" "500"
  |         Option "EmulateThirdButtonMoveThreshold" "50"
  |         Driver "evdev"
  | EndSection
1.3 Make evdev support touch screen
  The original evdev driver does not support Android input touch driver
  well. It needs some patches.
  Here're the main steps to patch and recompile a new one.
1.3.1 Install build environment and dependencies
  | sudo apt-get install build-essentials
  | sudo apt-get build-dep xserver-xorg-input-evdev
1.3.2 Fetch, patch, and compile the source code
  | sudo apt-get source xserver-xorg-input-evdev
  | cd xserver-xorg-input-evdev-2.9.0/src
  | GITHUB=https://github.com/TeeFirefly/xf86-input-evdev/tree/ba37709e2aab50354c9925ca1e975779a16c67dc
  | wget $GITHUB/src/emuThird.c
  | wget $GITHUB/src/evdev.c
  | wget $GITHUB/src/evdev.h
  | cd ..
  | make -j4
1.3.3 Install the newly built module
  | mv /usr/lib/xorg/modules/input/evdev_drv.so /usr/lib/xorg/modules/input/evdev_drv.so.orig
  | cp src/.libs/evdev_drv.so /usr/lib/xorg/modules/input/evdev_drv.so
  Restart system to take effect
