New Topic
Display Port (eDP) issue
115
Posted at 8/12/2015 15:00:09      View:19998 | Replies:11        Print      Only Author   [Copy Link] 1#
Hi all,
on Firefly RK3288, has anyone successfully tested the eDP output from the expansion headers?
Apart from the correct LCD parameters in the kernel DT, what changes (Android/Rockchip kernel 3.10) are required for eDP to work properly?
This is what eDP output currently looks like with a DP capable screen:
I have also tried various eDP LCDs, with same results.
Why is there no mention in the Firefly Wiki regarding using eDP? http://wiki.t-firefly.com/index.php/Firefly-RK3288/en
My included eDP dtsi (for eDP LCD):
  1. / {
  2.         disp_timings: display-timings {
  3.                         native-mode = <&timing0>;
  4.                         timing0: timing0 {
  5.                 screen-type = <SCREEN_EDP>;
  6.                 out-face    = <OUT_P888>;
  7.                 clock-frequency = <268500000>;
  8.                 hactive = <2560>;
  9.                 vactive = <1600>;
  10.                 hback-porch = <80>;
  11.                 hfront-porch = <120>;
  12.                 vback-porch = <4>;
  13.                 vfront-porch = <12>;
  14.                 hsync-len = <32>;
  15.                 vsync-len = <4>;
  16.                 hsync-active = <1>;
  17.                 vsync-active = <1>;
  18.                 de-active = <0>;
  19.                 pixelclk-active = <0>;
  20.                 swap-rb = <0>;
  21.                 swap-rg = <0>;
  22.                 swap-gb = <0>;
  23.                         };
  24.                };
  25. };
Copy the code
vip
Rank: 6Rank: 6
Posted at 8/13/2015 09:48:11        Only Author  2#
Firefly-RK3288 support EDP LCD, and tested it,  display normally.
Add EDP LCD is the same as LVDS.
like the attachment, it is a patch of supporting edp.
0001-kernel-dts-support-LCD-LP097Qx2.rar
888 Bytes, Down times: 144
Posted at 8/13/2015 10:31:43        Only Author  3#
zhansb Posted at 8/13/2015 09:48
Thank you zhansb, the patch you posted is basically what I have done in the kernel DT - my timings match the LCD requirements but I have also tried different timings with DP monitor after reading EDID data.
The resulting image has colour issues (seems RGB crossed):
Should the source (Firefly) ML lanes be crossed just after the expansion header? The DP cable should do the lanes crossing but I am not sure if this is also needed at the source.
What did you use for testing from the expansion header? A DP cable with the wires soldered to individual pins or a PCB with DP receptacle specifically designed for this task?
vip
Rank: 6Rank: 6
Posted at 8/13/2015 14:23:57        Only Author  4#
is this config match your edp lcd ?
Posted at 8/13/2015 14:32:15        Only Author  5#
Hardware connect please refer to the attachment。
Posted at 8/13/2015 20:55:47        Only Author  6#
Hi zhansb, yes RGB888 pixel format is accepted by the LCD - I have also tried 18 and 16bit observing the same results.
Hi cb_cb, thank you - I have confirmed that the pins are correctly wired between the Firefly eDP header and the DP receptacle. Can the eDP signal be used successfully with a DP cable (~1.5 meters) without signal issues?
Posted at 8/17/2015 12:06:20        Only Author  7#
Theoretical support 1.5 meters DP cable。Maybe you can try a shorter cable or reduce resolution.
Posted at 8/18/2015 14:06:41        Only Author  8#
cb_cb Posted at 8/17/2015 12:06
Hi cb_cb, I have tested with a high quality, shorter DP cable (1m) - the resulting image is identical as per above screenshots.
Can you confirm that you have tested the Firefly eDP output successfully with a DP cable to a monitor or DP screen? How was the cable connected to the expansion header?
A picture or schematic would greatly help.
I have noticed various things while experimenting and I wonder if you have had any previous experience with these subjects:
1. Changing the resolution in the kernel DT does not affect the detected (sink side) resolution which remains 1920x1080 - different image scaling is visible however.
2. The following DT parameters do not affect the resulting image where they should:
  1. swap-rb = <0>;
  2. swap-rg = <0>;
  3. swap-gb = <0>;
Copy the code
3. Kernel bootlog reports multiple error entries such as "rk32-edp: Input video stream is not detected" - eDP link training and EDID are successful.
4. Reversing the DCLK does not affect the image on screen.
5. HDMI driver/support cannot be disabled from the kernel configuration as code dependencies break and the build fails.
Do you (or anyone else here) happen to have the Rockchip documentation "RockChip_DSS Development Guide v1.2" in English? It contains several sections related to LCD, EDP, LVDS etc. including kernel and DTS configurations.
Posted at 8/19/2015 08:03:38        Only Author  9#
To confirm point 1, from above:
You will notice that the detected resolution (centre-bottom side of the screen) is 1920x1080 - this does not reflect what I set in the device tree. Why is that?
To obtain the stretched image like visible above I swapped hactive/vactive parameters, like so:
  1. hactive = <1200>;
  2. vactive = <1920>;
Copy the code
Posted at 8/19/2015 08:58:29        Only Author  10#
See resolution mismatch by reading framebuffer information:
  1. root@rk3288:/sys/class/graphics/fb0 # cat disp_info
  2. z-order:
  3.   layer3_sel_win[3]
  4.   layer2_sel_win[2]
  5.   layer1_sel_win[1]
  6.   layer0_sel_win[0]
  7. win0:
  8.   state:0,   fmt:ARGB888,   y_vir:320,   uv_vir:320
  9.   xact: 320,   yact: 240,   dsp_x: 320,   dsp_y: 240,   x_st:   0,   y_st:   0
  10.   y_h_fac:    4096,   y_v_fac:    4096,   uv_h_fac:    4096,   uv_v_fac:    4096
  11.   y_addr: 0x00000000,   uv_addr:0x00000000
  12. win1:
  13.   state:1,   fmt:ARGB888,   y_vir:1920,   uv_vir:0
  14.   xact:1920,   yact:1080,   dsp_x:1920,   dsp_y:1080,   x_st:   0,   y_st:   0
  15.   y_h_fac:    4096,   y_v_fac:    4096,   uv_h_fac:    4096,   uv_v_fac:    4096
  16.   y_addr: 0x108ca000,   uv_addr:0x00000000
  17. win2:
  18.   state:0
  19.   fmt:ARGB888
  20.   area0:  state:0,  y_vir: 320,  dsp_x: 320,  dsp_y: 240,  x_st:   0,  y_st:   0,  addr:0x00000000
  21.   area1:  state:0,  y_vir: 320,  dsp_x: 320,  dsp_y: 240,  x_st:   0,  y_st:   0,  addr:0x00000000
  22.   area2:  state:0,  y_vir: 320,  dsp_x: 320,  dsp_y: 240,  x_st:   0,  y_st:   0,  addr:0x00000000
  23.   area3:  state:0,  y_vir: 320,  dsp_x: 320,  dsp_y: 240,  x_st:   0,  y_st:   0,  addr:0x00000000
  24. win3:
  25.   state:0
  26.   fmt:ARGB888
  27.   area0:  state:0,  y_vir: 320,  dsp_x: 320,  dsp_y: 240,  x_st:   0,  y_st:   0,  addr:0x00000000
  28.   area1:  state:0,  y_vir: 320,  dsp_x: 320,  dsp_y: 240,  x_st:   0,  y_st:   0   addr:0x00000000
  29.   area2:  state:0,  y_vir: 320,  dsp_x: 320,  dsp_y: 240,  x_st:   0,  y_st:   0,  addr:0x00000000
  30.   area3:  state:0,  y_vir: 320,  dsp_x: 320,  dsp_y: 240,  x_st:   0,  y_st:   0,  addr:0x00000000
Copy the code
Above it's reported 1920x1080 - the DT is set to 1920x1200. What is overriding the resolution settings?
Could the display EDID or DPCD data be misinterpreted by the eDP driver?
Return to List
12
