cannot access /dev/ttyUSB0
96
Posted at 8/31/2015 15:22:25      View:8604 | Replies:9        Print      Only Author   [Copy Link] 1#
Hi, I have a kobuki, and want connect it to rk3288(ubuntu) but , list usb serial can show ttyUSB0,
when i use cm: lsusb, I see kubuki device. but cant connect to serial port ttyUSB0.
please help.
error message:
ls: cannot access /dev/ttyUSB0: No such file or directory
vip
Rank: 6Rank: 6
Posted at 9/1/2015 15:49:12        Only Author  2#
Refer to the following step:
1.make menuconfig
select  Device Drivers > USB support > USB Serial Converter support
<M>   USB CP210x family of UART Bridge Controllers
<M>   USB Prolific 2303 Single Port Serial Driver
change them to "M"
2. run the following command to make module:
make modules
mkdir modules_install
make INSTALL_MOD_PATH=./modules_install modules_install
3.copy [size=13.63636302948px]cp210x.ko and  pl2303.ko to firefly-rk3288  board from path(kernel/modules_install/lib/modules/3.10.0/kernel/drivers/usb/serial)
4.install ko file:
root@firefly:/mnt/ko# insmod pl2303.ko
root@firefly:/mnt/ko# insmod cp210x.ko
5.final you list the [size=13.63636302948px]ttyUSB* in [size=13.63636302948px]/dev/:
ls /dev/ttyUSB0
ttyUSB0
6.if wan to remove it ,just:
root@firefly:/mnt/ko# rmmod cp210x.ko
root@firefly:/mnt/ko# rmmod pl2303.ko
Posted at 9/1/2015 19:57:20        Only Author  3#
hi, thank for reply.
but i'm still got error :
Posted at 9/1/2015 21:44:10        Only Author  4#
kobuki chipset serial :  FT232R - USB UART IC
so i need FT232R user serial ?
Posted at 9/1/2015 22:01:25        Only Author  5#
Ltd FT232 USB-Serial (UART)
when lsusb:
lsusb
Bus 002 Device 002: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Posted at 1/19/2026 06:06:33        Only Author  6#
The content is so good, it’s an immediate like. Enhance your IT knowledge and get free ISA-IEC-62443 pass leader dumps. Wishing you success!
Posted at 2/1/2026 03:45:55        Only Author  7#
生活で他の人が何かやったくれることをいつも要求しないで、私が他の人に何かやってあげられることをよく考えるべきです。職場でも同じです。ボスに偉大な価値を創造してあげたら、ボスは無論あなたをヘアします。これに反して、あなたがずっと普通な職員だったら、遅かれ早かれ解雇されます。ですから、IT認定試験に受かって、自分の能力を高めるべきです。 Pass4TestのNutanixのNCP-EUC「Nutanix Certified Professional - End User Computing (NCP-EUC) 6.10 Exam」試験問題集はあなたが成功へのショートカットを与えます。IT 職員はほとんど行動しましたから、あなたはまだ何を待っているのですか。ためらわずにPass4TestのNutanixのNCP-EUC試験トレーニング資料を購入しましょう。
Posted at 2/8/2026 07:06:05        Only Author  8#
I truly appreciate your article; the content is truly amazing! Reliable SPLK-1003 exam notes offers amazing content, and it’s available to you without charge.
Posted at 2/20/2026 23:37:38        Only Author  9#
I really appreciate your work, it left a profound impact on me. Best of luck to everyone! The Exam sample OGEA-101 online exam papers are now shared for free!
Posted at 2/22/2026 04:43:07        Only Author  10#
This article is simply exceptional, I appreciate you sharing it. It’s nearly time for my CS0-003 study tool exam – wish me all the best!
