New Topic
how to control GPIO in Android application?
27
Posted at 9/7/2015 09:34:29      View9071 | Replies12        Print      Only Author   [Copy Link] 1#
Hi,
I want to create android application that is able to control GPIO, LED, Serial port.
I've searched a lot but can't get enough good answer.
I know it uses JNI interface in android app, but do now know in driver side.
would you give me effective example?
thanks
Jay
Posted at 9/7/2015 18:02:01        Only Author  2#
Please reference:
- http://falsinsoft.blogspot.jp/20 ... nux-user-space.html
- http://android.serverbox.ch/?p=972
Make sure your program has access permission to the files.
Posted at 9/9/2015 10:09:42        Only Author  3#
thanks for your reply.
would you give me more explanation?
how can I access UART serial by using TX, RX, GRD?
I need a specific guide or code..
Posted at 9/11/2015 10:33:57        Only Author  4#
zamster Posted at 9/9/2015 10:09
First refer to the uart driver wiki:
http://wiki.t-firefly.com/index.php/Firefly-RK3288/UART/en
If you are using uart3, you can access /dev/ttyS3.
Then google for "Linux serial programming", which will give you a bunch of
documents and examples. One is:
http://www.comptechdoc.org/os/li ... inux_pgcserial.html
Posted at 9/11/2015 16:27:33        Only Author  5#
busybee Posted at 9/11/2015 10:33
thanks.
one more question.
Do I have to make new uart driver for uart communications?
(if I'm using uart3 I can just access /dev/ttyS3 without making new uart driver..)
Posted at 9/11/2015 17:42:24        Only Author  6#
Same uart driver is already configured builtin for all the uart devices.
No need to make new one.
Posted at 9/11/2015 17:59:56        Only Author  7#
in the middle of page (http://wiki.t-firefly.com/index.php/Firefly-RK3288/UART/en),
what is meaning of "Turn on CONFIG_SERIAL_ROCKCHIP in kernel configuration"?
Compile and Flash KernelTurn on CONFIG_SERIAL_ROCKCHIP in kernel configuration, which will add corresponding drivers/tty/serial/rk_serial.c to kernel. Then compile the kernel as followed:
make firefly-rk3288.img
Posted at 9/12/2015 10:53:25        Only Author  8#
Add:
  CONFIG_SERIAL_ROCKCHIP=y
in your kernel/.config file
Posted at 1/15/2026 10:25:20        Only Author  9#
This article was really shocking; thank you for sharing! Best wishes for your exams! Heres the free Latest test PL-600 questions and answers resource.
Posted at 1/25/2026 21:54:15        Only Author  10#
This is a truly magnificent article, thank you for sharing your thoughts. The CPCE valid exam sample online content is amazing, and you can get it for free.
Return to List
12
