recover bootloader...
64
Posted at 9/12/2015 10:15:26      View:4498 | Replies:5        Print      Only Author   [Copy Link] 1#
Hi
My FirePrime board is broken..
So. I want to recover bootloader using MaskRom mode.
I try to bellow step... But it's fail ..
1. shot H/W two point...
2. writing the parameter
    sudo upgrade_tool di -p FirePrime_boot.txt # flash parameter
3. chceking serial log
    DDR Version 2.00 20140828
    In
    1A1A1F20   0
    1A1A2929   3
    LPDDR2
    29292929   F
    Bus Width=32 Col=10 Bank=8 Row=14 CS=2 Die Bus-Width=32 Size=1024MB
    mach:14
    OUT
    2.18 0
    ChipType = 9
    No.1 FLASH ID:ad de 14 a7 42 4a
other question.. why don't support compiled update.img ? (URL is broken.)
Thx...
Posted at 9/12/2015 11:08:14        Only Author  2#
Firmware download link is fixed, thank you
If you want to recovery bootloader, either:
- Flash the whole image again:
    sudo upgrade_tool uf /path/to/update.img
- Update the bootloader
    sudo upgrade_tool DB /path/to/loader.bin   # this download the loader to the board
    sudo upgrade_tool UL  /path/to/loader.bin   # this shall upgrade to loader of the board
Posted at 9/12/2015 15:08:26        Only Author  3#
Thanks. your reply
I soloved this problem.
thx.
Posted at 9/15/2015 17:08:03        Only Author  4#
Hi, Stephon!
I have the same problem as you.
Can you tell me point that shot H/W two point(1. shot H/W two point...)?
vip
Rank: 6Rank: 6
Posted at 9/16/2015 11:04:46        Only Author  5#
@newold, refer to attachment
Posted at 9/16/2015 12:02:54        Only Author  6#
zhansb Posted at 9/16/2015 11:04
Thanks. your reply
Have a nice day!
