Bad opengles performance
9
Posted at 10/26/2015 02:17:27      View:4043 | Replies:5        Print      Only Author   [Copy Link] 1#
Hi i just flashed the mainline kernel image from the wiki, with the triangle application test i have only arround 40fps, can someone give me some advice to get better performance?
I have tested another application that run smooth at 60fps on another (weaker) board and i get 1fps...
I think i'm missing something
Posted at 12/4/2015 20:03:28        Only Author  2#
I saw this link http://wiki.t-firefly.com/index. ... #Prebuilt_Firmware.
I install Firefly-RK3288_MainlineKernel-Ubuntu14.04_201503191033   on Firefly.
After that  device is not work
LED is not on and USB ports are not work
vip
Rank: 6Rank: 6
Posted at 12/8/2015 16:14:10        Only Author  3#
can you show the uart2_debug  log
Posted at 12/21/2015 18:34:32        Only Author  4#
tatmarg Posted at 12/4/2015 20:03
I install Firefly-RK3288_M ...
I tried to do next steps but when I flashed linux-boot-miniroot to boot partition nothing is not booting??
Posted at 12/22/2015 14:16:51        Only Author  5#
What next step?
Please plug out the TF-card before you flash the firmware and boot the device.
If it still not works, use a serial usb adapter for debugging this startup problem.
