How to set physical resolution to 1280x720 @ 30fps
16
Posted at 12/7/2015 15:42:11      View:4254 | Replies:6        Print      Only Author   [Copy Link] 1#
Hi,
The default resolution of rk3288 is 1080p @ 60fps, my project may need 720p@30fps to save much of the system resources e.g. GPU/CPU power even maybe acceleration of surface rendering.
Would you guys give some tips, thanks in advance~
sincerely
Maye
Posted at 12/14/2015 05:24:48        Only Author  2#
Hi,
To set the resolution to your needs, you have to modify the Drive Tree file of Kernel located in <kernel_source>/arm/arch/boot/dts folder and compile the kernel again after setting your required resolution.
This is same for both Linux and Android.
So read the manual of how to compile the Kernel for Android or Linux and you can get it done.
Cheers,
Posted at 1/10/2026 04:07:54        Only Author  3#
Your article really opened my eyes, I’m so grateful for it. This is the PL-900 PDF Download test that helped me achieve a promotion and raise. It's available to you for free today, and I wish you success in reaching your career goals.
Posted at 1/11/2026 14:36:23        Only Author  4#
KaoGuTi AVIXA的CTS-I考試培訓資料得到廣大考生的稱譽已經不是最近幾天的事情了,說明KaoGuTi AVIXA的CTS-I考試培訓資料信得過,確實可以幫助廣大考生通過考試,讓考生沒有後顧之憂,KaoGuTi AVIXA的CTS-I考試培訓資料暢銷和同行相比一直遙遙領先,率先得到廣大消費者的認可,口碑當然不用說,如果你要參加 AVIXA的CTS-I考試,就趕緊進KaoGuTi這個網站,相信你一定會得到你想要的,不會錯過就不會後悔,如果你想成為最專業最受人矚目的IT專家,那就趕緊加入購物車吧。
Posted at 1/14/2026 12:42:19        Only Author  5#
I was blown away by how much I learned from it. The Latest NCP-US dumps ppt test questions are free! Wishing you success in your exam preparations!
Posted at 1/18/2026 08:00:07        Only Author  6#
IIA-CIA-Part3인증시험패스는 쉬운 일은 아닙니다. 높은 전문지식은 필수입니다.하지만 자신은 이 방면 지식이 없다면 PassTIP가 도움을 드릴 수 있습니다. PassTIP의 전문가들이 자기만의 지식과 지금까지의 경험으로 최고의 IT인증관련자료를 만들어 여러분들의 고민을 해결해드릴 수 있습니다. 우리는 최고의IIA-CIA-Part3인증시험문제와 답을 제공합니다. PassTIP는 최선을 다하여 여러분이 한번에IIA-CIA-Part3인증시험을 패스하도록 도와드릴 것입니다. 여러분은 우리 PassTIP 선택함으로 일석이조의 이익을 누릴 수 있습니다. 첫쨰는 관여지식은 아주 알차게 공부하실 수 있습니다.둘째는 바로 시험을 안전하게 한번에 통과하실 수 있다는 거죠.그리고 우리는 일년무료 업데이트서비스를 제공합니다.덤프가 업뎃이되면 우리는 모두 무료로 보내드립니다.만약 시험에서 실패한다면 우리 또한 덤프비용전액을 환불해 드립니다.
Posted at 2/18/2026 05:56:38        Only Author  7#
我們都知道在現在這個競爭激烈的IT行業,擁有一些IT相關認證證書是很有必要的。IT認證證書是對你的IT專業知識和經驗的最好證明。在IT行業中Fortinet FCP_FAZ_AD-7.4 認證考試是一個很重要的認證考試,但是通過Fortinet FCP_FAZ_AD-7.4 認證考試是有一定難度的。但是為了能讓工作職位有所提升花點金錢選擇一個好的培訓機構來幫助你通過考試是值得的。NewDumps擁有最新的針對Fortinet FCP_FAZ_AD-7.4認證考試的培訓資料,與真實的考試很95%相似性。如果你使用NewDumps提供的培訓,你可以100%通過考試。如果你考試失敗,我們會全額退款。
