Putting HDMI in portrait mode
42
Posted at 1/29/2016 04:25:05      View:2876 | Replies:2        Print      Only Author   [Copy Link] 1#
Hi,
I'm trying to put the HDMI output in portrait mode. My app tries to set the orientation to portrait but it always displays in landscape. Is there anything I need to change to enable portrait mode?
Jim
Posted at 1/30/2016 05:19:48        Only Author  2#
This is a typical questions. I belive, the best solution is to flash the device the last version of firmware 5.1 and you get rotation as a part of the firmware. Otherwise you cannot rotate as it is blocked in kernel.
B.r. Vlad.
Posted at 2/1/2016 22:24:12        Only Author  3#
Thanks, this worked with 5.1.
