New Topic
Kernel 3.14 or above for ubuntu 14.04 is required
175
Posted at 2/1/2016 02:46:50      View18759 | Replies28        Print      Only Author   [Copy Link] 1#
Hello,
My device is Firefly-RK3288 running ubuntu  flashed from:
Firefly-RK3288_Ubuntu14.04_201501271612.img
Is there a build for UBUNTU image with a newer kernel than 3.10 ? I am working on an application where it requires to update according to the kernel version.
output of the following command :
apt-get install -y linux-headers-`uname -r`
Returns the following errors :
E: Unable to locate package linux-headers-3.10.0
E: Couldn't find any package by regex 'linux-headers-3.10.0'
I would really appreciate if someone can help.
Posted at 3/30/2016 16:51:22        Only Author  recommend
busybee Posted at 3/30/2016 15:30
In your prevous post, you mention that
Hello Busybee,
After letting me struggle for over a month, you finally realized that your image/board does not come with linux headers package. I am now more disappointed.
I do not regret giving you the benefit of the doubt, at least now I know that your board has a major handicap when it comes to linux. therefore I consider the time wasted a contribution from me towards those who are thinking of buying your board.
Today your board is a pure android oriented device so people trying to use it with Linux must understand that there are obstacles that cannot be overcome.
What does it take you to build an image with linux headers packed ? I am very confident that a huge community is looking for a powerful board like yours with  full fledged linux. At this point unfortunately I regret to say that it is not the case of your board.
Finally I do not expect a positive answer and I consider this case closed. I hope my experience will help Linux fans to think twice before making a decision.
Posted at 3/3/2016 00:56:57        Only Author  3#
Hello,
Unfortunately I lost interest into Firefly and moved to NUC from Intel.
It is really sad not to see linux development for the Firefly, while the the focus is on Android only.
Well could not wait longer and I am happy with the NUC, more versatile and flexible.
Good luck Firefly while I see you need more than luck though.
Posted at 3/4/2016 15:35:51        Only Author  4#
Sorry @tedd77 .  We'd like to listen to your advice about Linux development for Firefly.
Would you like the mainline kernel running on the board and more recent Linux distribution?
Or something else?
Posted at 3/4/2016 17:49:19        Only Author  5#
busybee Posted at 3/4/2016 15:35
Would yo ...
Hello,
Id like this kind of stuff me too. Also if you have the time to evaluate the RT patches on the RK3288 it would be great for me. I dont feel confident enough in my linux skills to do that kind of work myself
I also share the feeling of tedd77 about the linux support vs the android one. I can easily understand why this is the case because the commercial applications of the RK3288 have been mainly TV boxes for which the android OS is good. My projects on the contrary are focused on usage where the main concern is the real time behaviour, the CPU efficiency (I need to do  a lot of computation), and my GUI needs are rather limited.
The CPU is the main point for me, thats why I posted a question on this forum concerning the RK3399 (based on 2 Cortex-A72 cores).
To finish on a positive note, I want to say that I greatly appreciate that you have made available such boards for anyone. Thank you for that.
Posted at 3/10/2016 02:34:39        Only Author  6#
Hello busybee,
I am ready to give it a chance, but to be honest I am not a geek in linux.
If you are ready to guide me through then please let us proceed.
I read about mainline and it was not advisable to use it, I do not care about the version as much as I care about supported Kernels. I searched everywhere on the internet for the Kernel 3.10 that you currently have and it is not available.
I am unable to compile some softwares due to the lack of kernel headers and that is why I had to move to NUC since everything was available.
Your board is not cheaper than NUC by the way however it is smaller and that is why I am ready to give it another try if you are serious about your offer to help.
Please let me know at your earliest.
Finally my other disappointment was the time t-firefly took to consider my post and to react to it.
Posted at 3/10/2016 18:50:34        Only Author  7#
Would yo ...
Hello busybee,
I am waiting for your reply.
Posted at 3/12/2016 11:27:53        Only Author  8#
Please read the wiki page here:
http://wiki.t-firefly.com/index. ... 288/Build_kernel/en
Feel free to post any problem you meet here.
Posted at 3/15/2016 07:35:48        Only Author  9#
busybee Posted at 3/12/2016 11:27
http://wiki.t-firefly.com/index.php/Firefly-RK3288/Build_kernel/e ...
Hello,
I am having an issue.
Do I have to replace the /path/to/prebuilts with something else ?
If not then the command
make -j8 firefly-rk3288.img is failing with path not found
Please advise
Posted at 3/15/2016 14:11:00        Only Author  10#
Yes, you have to replace it with the directory of your compiling toolchain.
Things will be easier if you have our Android SDK, which contains the toolchain.
Posted at 3/15/2016 19:47:35        Only Author  11#
the link to get it from please ?
Return to List
123
