Technical briefing for Firefly-RK3288-Reload: Updates firmware and codes
385
super moderator
Rank: 8Rank: 8
Posted at 3/15/2016 11:30:32      View7624 | Replies7        Print      Only Author   [Copy Link] 1#
Android5.1 update:
1.fix lcdc set freq error
2.update rgb2hdmi resolution
3.modify scale default 100%
Ubuntu update:
1.ubuntu single system update paramter file
Please refer to  the Download Android SDK on wiki, and upgrade to the latest tag: Firefly-RK3288-Reload_Android5.1_201603151017
You can download the latest firmware from the following links:
Posted at 3/15/2016 12:10:46        Only Author  recommend
Please add Mali 3D drivers to Lubuntu part and RGA 2D drivers for acceleration.
"as rockchip rk3066 and rk3188 devices are also equiped with ARM's mali 400 GPU for 3D acceleration, lgeek has made an improved version of ssvb's work https://github.com/lgeek/xf86-video-fbturbo and added support for rk3188 2D by using its hardware acceleration unit (RGA) and some specific optimization for copying video windows (XV)." Maybe it can work for RK3288 also.
Is it possible to update Lubuntu image to 16.04 instead of 14.04?
Posted at 5/13/2016 05:20:39        Only Author  3#
Can you please give me the link for downloading the source for the RK3288 reload kernel?
Posted at 5/18/2016 22:17:03        Only Author  4#
Can we boot from SD card in the rk3288-reload board?
If so, can you please let me know where can I find the image for SD card load?
Thanks
Posted at 5/26/2016 20:24:39        Only Author  5#
Hello all,
I have a question: How to build android 5.1 for the firefly rk3288 reloaded?
First I do:
  1. cd ~/proj/firefly-rk3288-lollipop/kernel
  2. make firefly-rk3288-reload_defconfig
  3. make -j8 firefly-rk3288.img
Copy the code
And then:
  2. . build.sh
  3. make -j8
  4. ./mkimage.sh
Copy the code
But the built image does not reflect the HDMI outputs. I cannot change the output resolution. I cannot display 4K (max available is only 1080p).
For some reason it says "TARGET_PRODUCT=rk3288_box". I think it should be something like "reloaded" or something. Or maybe this has nothing to do with it.. maybe?
Help!!!
Posted at 1/14/2026 22:22:24        Only Author  6#
Thank you for sharing such an insightful and uplifting article! Im offering the Latest AIGP exam braindumps resources for freegood luck!
Posted at 1/17/2026 06:37:22        Only Author  7#
This article really expanded my views, thank you for the fantastic share! Heres the NSE5_FSW_AD-7.6 valid exam lab questions exam that helped me achieve career growth with a promotion and raise. Its free for everyone todaybest wishes in your career!
Posted at 3/7/2026 04:38:13        Only Author  8#
Fast2test는 몇년간 최고급 덤프품질로 IT인증덤프제공사이트중에서 손꼽히는 자리에 오게 되었습니다. Amazon SOA-C02-KR 덤프는 많은 덤프들중에서 구매하는 분이 많은 인기덤프입니다. Amazon SOA-C02-KR시험준비중이신 분이시라면Amazon SOA-C02-KR한번 믿고 시험에 도전해보세요. 좋은 성적으로 시험패스하여 자격증 취득할것입니다.
