Firefly-RK3288 Android 5.1 flashing
54
Posted at 4/7/2016 16:34:09      View:5512 | Replies:9        Print      Only Author   [Copy Link] 1#
Hello,
I flashed several times this board with the AndroidTool, but the Android 5.1 cannot start after flashing... I tried more versions. I used the EraseFlash option too, but it wasn't help. At the first booting I got the attached massegages but after when the Android booting logo appearing the animation stops and it freeze. The restart doesn't help.
I tried the LowerFormat option too, but not helped.
I think the problem is around the partitioning...
Do you have any idea?
Thank you,
Roland NAGY
Posted at 4/12/2016 21:01:40        Only Author  2#
I tried to flash again and logging with logcat, sometimes I got results... But most of the cases it can't even log the boot (dies before that).
log_5.1_fail.zip (36.13 KB, Down times: 1)
vip
Rank: 6Rank: 6
Posted at 4/13/2016 09:39:50        Only Author  3#
which version of androidtool and firmware so you used?
Posted at 4/13/2016 16:25:20        Only Author  4#
The AndroidTool is v2.35 and the firmware... I tried some firmware: 2015.09.15., 2015.12.31., 2016.03.11. but none of them working.
Posted at 4/13/2016 21:37:21        Only Author  5#
I made some logs via the debugging header (UART) from the Firefly board, during the flashing and after that 3 times boot. But the systems always stops during the boot.
device_log.ZIP (88.07 KB, Down times: 2)
Posted at 4/14/2016 21:34:53        Only Author  6#
I can enter into maskrom mode from AndroidTool after EraseFlash and after that reflashing to firmware, but that doesn't help.
Posted at 4/19/2016 14:59:57        Only Author  7#
Nobody has an answer for this issue?
Posted at 4/20/2016 17:10:25        Only Author  8#
I upload a new log from the debug interface, maybe somebody can help me...
capture.zip (111.85 KB, Down times: 1)
Posted at 6/30/2016 23:52:38        Only Author  9#
I have the same problem
Posted at 1/22/2026 05:08:34        Only Author  10#
Thank you for sharing this remarkable article! Best wishes to everyone! SAP-C02 reliable free study questions test questions are now available for free.
