TFTP support in uboot for rk3288
80
Posted at 4/27/2016 18:54:53      View6391 | Replies9        Print      Only Author   [Copy Link] 1#
Hi,
Can someone point me to the link for bootloader source code that has TFTP enabled. I have tried building code from http://git.denx.de/?p=u-boot/u-boot-rockchip.git;a=summary and looks like it does not generated RK3288UbootLoader_V2.19.01.bin and upgrade_tool fails flashing u-boot.bin
I could boot the board using SDcard with these images and has tftp support . But I would like to understand how to flash this bootloader to eMMC.
Tried generating RK3288UbootLoader_V2.19.01.bin from u-boot.bin using rktools but that did not help, meaning boot does not boot to uboot.
Thanks
Posted at 4/27/2016 19:24:06        Only Author  2#
U-Boot source code for Firefly
https://bitbucket.org/T-Firefly/ ... -boot/?at=fireprime
Use 'make rk3288_box_defconfig'
https://bitbucket.org/T-Firefly/ ... r=file-view-default
Then a normal 'make'
I can't remember all the steps.
Posted at 4/27/2016 19:36:46        Only Author  3#
Hi Dewet,
Could you please confirm if this uboot has GMAC support ? I mean to say does it has Ethernet support enabled?
Thanks
Posted at 4/27/2016 19:41:03        Only Author  4#
banavathvishnu Posted at 4/27/2016 19:36
Hi Dewet,
Could you please confirm if this uboot has GMAC support ? I mean to say does it has Ether ...
Gigabit Ethernet support comes from the driver in the kernel as far as I know.
You can also follow all the posts here, a user got 4.6 Linux kernel running with Slackware Linux on Firefly, maybe there are also different u-boot source code to make it boot?
http://bbs.t-firefly.com/forum.p ... &extra=page%3D1
Posted at 4/27/2016 19:48:15        Only Author  5#
yeah you are right GbE driver is in kernel. But the point I'm trying to make here is - does rockchip bootloader supports Ethernet on firefly-rk3288  ?
I would need this board support in boot loader because, I want to download kernel Image via TFTP on the board. This will enabled me the test different kernel with a line change (change in symlink) which is much much better than flashing each image at a single time. This will help folks working remotely and want to change kernel.
Thanks
Posted at 1/11/2026 08:43:17        Only Author  6#
Thank you for your article, it was incredibly enlightening. Sharing the New C_ABAPD_2507 study notes materials for freewishing you good luck!
Posted at 1/15/2026 12:18:23        Only Author  7#
Fast2test hat vielen IT-Zertifizierungskandidaten geholfen. Und Fast2test bekommt gute Bewertung von den Kandidaten. Die Erfolgsquote von Fast2test Prfungsfragen erreicht 100%, was auch die Tatsache von vielen Kadidaten geprft werden. Wenn Sie sich sehr mde fr die Vorbereitung der Pegasystems PEGACPBA24V1 Zertifizierungsprfung fhlen, können Sie die PEGACPBA24V1 Prfungsunterlagen nicht ignorieren. Das ist ein Werkzeug fr die hocheffektive Vorbereitung der Pegasystems PEGACPBA24V1 Prfung. Es kann Ihre Effektivität am größten Teil erhöhen.
restricted members
Posted at 2/14/2026 01:08:53        Only Author  8#
The article is absolutely magnificent, thank you for sharing it with us. The SecOps-Generalist exam material content is amazing, and its available to you without charge.
Posted at 2/15/2026 23:52:18        Only Author  9#
PK0-005Jѧ̲ĤϡCompTIATYԇY100ϸ񤹤뤳Ȥ^ޤ JpexamPK0-005JɥȥȤƷ|Ť֤äƤޤ PK0-005Jȥ`˥󥰥֥쥤פκϸʤ98100Ǥ PK0-005J}ȫm뤳ȤǤޤ 줿Ʒ|_J뤿PK0-005JѧʂΟoϥǥ⤬ޤ PK0-005JԇY}oϤǥ`ɤޤꡢ}˜㤷CompTIA Project+ Certification Exam (PK0-005ձZ)ԇY˺g˺ϸ񤷤ޤ
Posted at 2/17/2026 19:03:37        Only Author  10#
This is a wonderfully inspiring article, thank you for sharing! Boost your IT knowledge with free NS0-005 test cost. Wishing you all the best in your studies!
