【Linux】
[Core-PX30-JD4] Can not boot from SD card
Posted at 3/23/2022 18:28:17
Hi,
I have a Core-PX30-JD4 with the industrial mainboard MB-JD4-RK3328 & PX30 , so the story is i am trying to boot the OS from SD card rather than flash directly to eMMC with the new firmware I just have build by using buildroot rootfs exactly like the tutorial in here link to have an .img file in rockdev/pack . But when i use etcher to flash the firmware to the SD card, it popped up a warning message that it can not find the partition table, I can see that there are 2 parameter.txt and package-file, but the problem is that i do not know how to apply those to flash with dd or etcher.
So if there is anyone know the answer or even any hint please help?
Also, I have another question that in other board like beagle bone we have a button to hold to make the board boot from sd card rather than eMMC, is there a similar to do so in this board or we have to do some command in uboot command line to make it boot from SDcard?
Thanks you for any helps,
Tu |
