[Linux] [Core-PX30-JD4] Can not boot from SD card
67
Linux [Core-PX30-JD4] Can not boot from SD card
Posted at 3/23/2022 18:28:17      View4489 | Replies4        Print      Only Author   [Copy Link] 1#
Hi,
I have a Core-PX30-JD4 with the industrial mainboard MB-JD4-RK3328 & PX30 , so the story is i am trying to boot the OS from SD card rather than flash directly to eMMC with the new firmware I just have build by using buildroot rootfs exactly like the tutorial in here link to have an .img file in rockdev/pack .  But when i use etcher to flash the firmware to the SD card, it popped up a warning message that it can not find the partition table,  I can see that there are 2 parameter.txt and package-file, but the problem is that i do not know how to apply those to flash with dd or etcher.
So if there is anyone know the answer or even any hint please help?
Also, I have another question that in other board like beagle bone we have a button to hold to make the board boot from sd card rather than eMMC, is there a similar to do so in this board or we have to do some command in uboot command line to make it boot from SDcard?
Thanks you for any helps,
Tu
Posted at 3/28/2022 16:21:45        Only Author  2#
Hi, because it is different from the general firmware format, you cannot use the tool Etcher to make a boot card.
You can use the tool 'SD_Firmware_Tool.exe' to make a boot card, select the 'SD Boot' option. Reference, https://wiki.t-firefly.com/en/Fi ... de_firmware_sd.html
The default boot priority of TF card is higher than eMMC. When the boot card is recognized, it will boot from the TF card.
Posted at 4/6/2022 17:01:46        Only Author  3#
ʱĺ Posted at 3/28/2022 16:21
Hi, because it is different from the general firmware format, you cannot use the tool Etcher to make ...
Thank you for your answer. I can do it now.
Posted at 1/13/2026 12:20:40        Only Author  4#
Im really thankful for your article, it left a strong impression. The New OGEA-101 study guide platform offers detailed material at no cost, aimed at assisting you.
Posted at 1/16/2026 11:09:39        Only Author  5#
DeutschPrfung ist eine professionelle Webseite, die die neuesten Testaufgaben und Antworten von Salesforce Plat-Arch-203 Zertifizierungsprfung bietet. Es ist sicherlich Ihre beste Wahl, mit unseren Lehrbchern die Salesforce Plat-Arch-203 Prfung vorzubereiten. DeutschPrfung wird Ihnen helfen, in begrenzter Zeit die Plat-Arch-203 Prfung so schnell wie möglich zu bestehen. Wenn es irgendein Qualitätsproblem von den Lehrbchern gibt oder Wenn Sie die Plat-Arch-203 Prfung nicht bestehen, versprechen wir Ihnen eine bedingungslose volle Rckerstattung.
