[Linux] How to enable device mode with Firefly-RK3399?
14
【Linux】 How to enable device mode with Firefly-RK3399?
Posted at 2/18/2019 16:54:54      View:3780 | Replies:4        Print      Only Author   [Copy Link] 1#
Hello,
     I want to use the Firefly RK3399, type C port to work in device mode. But I see it does not change the role. How can I change the role as a  device? I am using ubuntu 18.04 image.
Thanks
vip
Rank: 6Rank: 6
Posted at 2/20/2019 17:23:42        Only Author  2#
Maybe you can reference the setup script of adbd in buildroot?
https://github.com/rockchip-linu ... ckage/rockchip/adbd
Posted at 1/14/2026 12:47:39        Only Author  3#
CWNP인증 CWNA-109시험을 가장 빠른 시일내에 가장 쉬운 방법으로 패스하는 방법을 고심초사한끝에 Pass4Test에서 연구해 내었습니다. 그건 바로ass4Test의CWNP인증 CWNA-109덤프로CWNP인증 CWNA-109시험에 대비하는것입니다. Pass4Test의CWNP인증 CWNA-109덤프품질을 검증하려면 구매사이트의 무료샘플을 체험해보시면 됩니다.자격증을 많이 취득하여 멋진 IT전문가로 되세요.
Posted at 1/20/2026 10:33:57        Only Author  4#
如果你想參加1Y0-342認證考試,那麼是使用1Y0-342考試資料是很有必要的。如果你正在漫無目的地到處尋找參考資料,那麼趕快停止吧。如果你不知道應該用什麼資料,那麼試一下NewDumps的1Y0-342考古題吧。這個考古題的命中率很高,可以保證你一次就取得成功。與別的考試資料相比,這個考古題更能準確地劃出考試試題的範圍。這樣的話,可以讓你提高學習效率,更加充分地準備1Y0-342考試。
Posted at 2/22/2026 10:52:08        Only Author  5#
Your article is magnificent, thank you for sharing it with us! Sharpen your IT knowledge with free FCP_FAZ_AN-7.4 official practice test. Best of luck to you!
