[Linux] How to enable device mode with Firefly-RK3399?
14
Linux How to enable device mode with Firefly-RK3399?
Posted at 2/18/2019 16:54:54      View3912 | Replies4        Print      Only Author   [Copy Link] 1#
Hello,
     I want to use the Firefly RK3399, type C port to work in device mode. But I see it does not change the role. How can I change the role as a  device? I am using ubuntu 18.04 image.
Thanks
vip
Rank: 6Rank: 6
Posted at 2/20/2019 17:23:42        Only Author  2#
Maybe you can reference the setup script of adbd in buildroot?
https://github.com/rockchip-linu ... ckage/rockchip/adbd
Posted at 1/14/2026 12:47:39        Only Author  3#
CWNP인증 CWNA-109시험을 가장 빠른 시일내에 가장 쉬운 방법으로 패스하는 방법을 고심초사한끝에 Pass4Test에서 연구해 내었습니다. 그건 바로ass4Test의CWNP인증 CWNA-109덤프로CWNP인증 CWNA-109시험에 대비하는것입니다. Pass4Test의CWNP인증 CWNA-109덤프품질을 검증하려면 구매사이트의 무료샘플을 체험해보시면 됩니다.자격증을 많이 취득하여 멋진 IT전문가로 되세요.
Posted at 1/20/2026 10:33:57        Only Author  4#
1Y0-342JCԇNʹ1Y0-342ԇYǺбҪġoĿĵص̎҅YϣNsֹͣɡ㲻֪ԓʲNYϣNԇһNewDumps1Y0-342}ɡ@}ʺܸߣԱCһξȡóɹceĿԇYȣ@}ܜʴ_؄ԇԇ}Ĺ@ӵԒ׌ߌWЧʣӳֵ؜ʂ1Y0-342ԇ
Posted at 2/22/2026 10:52:08        Only Author  5#
Your article is magnificent, thank you for sharing it with us! Sharpen your IT knowledge with free FCP_FAZ_AN-7.4 official practice test. Best of luck to you!
