[Android] RK3568 Camera Driver - Interlaced Mode Only Supported in Selfpath
21
Android RK3568 Camera Driver - Interlaced Mode Only Supported in Selfpath
Posted at 2/18/2025 15:21:36      View2408 | Replies4        Print      Only Author   [Copy Link] 1#
Hi everyone,
I'm currently working on a camera driver using the RK3568 SDK and have modified the kernel to support interlaced mode. According to the documentation, interlaced mode should be supported in the selfpath, and I have set the field parameter as follows:
  1. .field = V4L2_FIELD_INTERLACED,
Copy the code
However, when I run the camera in the Android environment, I only get the following log message:
  1. only selfpath support interlaced
Copy the code
Questions:
  • Has anyone encountered this issue before?
  • Are there any additional configurations required for interlaced mode in RK3568?
  • Could this be a limitation in Android's Camera HAL or a driver-level issue?
Any insights or suggestions would be greatly appreciated!
Thanks in advance. 🚀
rk3568_camera_interlaced_questions.log.tar.gz
776 Bytes, Down times: 1
Posted at 1/11/2026 07:47:03        Only Author  2#
Thank you for sharing this remarkable article, it truly impressed me. I owe my promotion and raise to the Valid test Databricks-Certified-Data-Analyst-Associate cram pdf questions, and today Im sharing them for free with all of you!
Posted at 1/12/2026 21:53:57        Only Author  3#
This article is absolutely amazing, thank you for sharing! The New MB-800 exam topics pdf helped me secure a promotion and raise. Now, Im giving it away for free. May your career paths be filled with success!
Posted at 1/20/2026 12:09:26        Only Author  4#
Your article is nothing less than magnificent, thank you for sharing! The rich material in PCCP reliable exam dumps sheet is available to you for free, intended to help you.
Posted at 2/3/2026 20:06:36        Only Author  5#
The article is very rich in content, and I feel that I have benefited greatly. Thanks to Marketing-Cloud-Administrator latest test topics pdf, I secured a promotion and pay raisetoday, Im sharing it for free!
