[Android] RK3568 Camera Driver - Interlaced Mode Only Supported in Selfpath
21
Android RK3568 Camera Driver - Interlaced Mode Only Supported in Selfpath
Posted at 2/18/2025 15:21:36      View2465 | Replies3        Print      Only Author   [Copy Link] 1#
Hi everyone,
I'm currently working on a camera driver using the RK3568 SDK and have modified the kernel to support interlaced mode. According to the documentation, interlaced mode should be supported in the selfpath, and I have set the field parameter as follows:
  1. .field = V4L2_FIELD_INTERLACED,
Copy the code
However, when I run the camera in the Android environment, I only get the following log message:
  1. only selfpath support interlaced
Copy the code
Questions:
  • Has anyone encountered this issue before?
  • Are there any additional configurations required for interlaced mode in RK3568?
  • Could this be a limitation in Android's Camera HAL or a driver-level issue?
Any insights or suggestions would be greatly appreciated!
Thanks in advance. 🚀
rk3568_camera_interlaced_questions.log.tar.gz
776 Bytes, Down times: 1
Posted at 1/11/2026 07:47:03        Only Author  2#
Thank you for sharing this remarkable article, it truly impressed me. I owe my promotion and raise to the Valid test Databricks-Certified-Data-Analyst-Associate cram pdf questions, and today Im sharing them for free with all of you!
Posted at 1/12/2026 21:53:57        Only Author  3#
This article is absolutely amazing, thank you for sharing! The New MB-800 exam topics pdf helped me secure a promotion and raise. Now, Im giving it away for free. May your career paths be filled with success!
Posted at 1/20/2026 12:09:26        Only Author  4#
Your article is nothing less than magnificent, thank you for sharing! The rich material in PCCP reliable exam dumps sheet is available to you for free, intended to help you.
