[General] C_THR87_2505シュミレーション問題集、C_THR87_2505日本語試験対策
100
【General】 C_THR87_2505シュミレーション問題集、C_THR87_2505日本語試験対策
Posted at 2/20/2026 22:50:15      View:114 | Replies:0        Print      Only Author   [Copy Link] 1#
ちなみに、Xhs1991 C_THR87_2505の一部をクラウドストレージからダウンロードできます:https://drive.google.com/open?id=17H_-C619uutuK8PjBXIbrn2hONutFu8O
親愛なるお客様、当社のウェブサイトにある優れた学習教材の助けを借りて試験を受ける準備ができている場合、選択は素晴らしいものになります。 C_THR87_2505トレーニング資料:SAP Certified Associate - Implementation Consultant - SAP SuccessFactors Variable Payは優れた選択肢であり、特に時間をかけずに試験に合格し、成功することに熱心な方に役立ちます。 次のように、すばらしい製品を詳細に紹介する自由を考えてみましょう。
SAP C_THR87_2505 認定試験の出題範囲:
トピック出題範囲
トピック 1
  • Business Goals and Goal Weights: This section of the exam measures skills of SAP Consultants in setting up business goals and assigning weights. It includes the alignment of goals with corporate strategy and their influence on individual or group bonus outcomes.
トピック 2
  • Bonus Calculation Methods: This section of the exam measures the skills of Compensation Analysts and covers the configuration of different bonus calculation methods within the Variable Pay module. It includes defining logic that calculates payouts based on employee performance and business results.
トピック 3
  • Employee History Data and Background Element: This section of the exam measures the skills of Compensation Analysts in managing employee history and background elements. It involves mapping historical records and compensation-related fields to ensure data accuracy for calculations.
トピック 4
  • Eligibility: This section of the exam evaluates the ability of SAP Consultants to define and configure eligibility rules. It includes setting criteria for plan participation and ensuring the correct employee population is included in bonus planning.
トピック 5
  • Integration Scenarios: This section of the exam assesses the ability of Compensation Analysts to work with integration scenarios. It covers data transfer and alignment between SuccessFactors modules like Employee Central and Variable Pay.
トピック 6
  • Variable Pay Program Settings: This section of the exam assesses the knowledge of SAP Consultants in setting up variable pay program settings. It focuses on cycle configuration, plan types, and the underlying parameters that define how bonus programs operate.
トピック 7
  • Variable Pay Form: This section of the exam assesses the proficiency of SAP Consultants in configuring the Variable Pay form. It includes layout adjustments, display logic, and content settings necessary for presenting bonus information to managers and planners.
トピック 8
  • Reports and Reward Statements: This section of the exam evaluates the knowledge of Compensation Analysts in generating reports and reward statements. It focuses on tools for communicating results to stakeholders and visualizing data through templates and dashboards.
素敵-便利なC_THR87_2505シュミレーション問題集試験-試験の準備方法C_THR87_2505日本語試験対策もう既にSAPのC_THR87_2505認定試験を申し込みましたか。「もうすぐ試験の時間なのに、まだ試験に合格する自信を持っていないですが、どうしたらいいでしょうか。何か試験に合格するショートカットがあるのですか。試験参考書を読み終わる時間も足りないですから・・・」いまこのような気持ちがありますか。そうしても焦らないでくださいよ。試験を目前に控えても、ちゃんと試験に準備するチャンスもあります。何のチャンスですかと聞きたいでしょう。それはXhs1991のC_THR87_2505問題集です。これは効果的な資料で、あなたを短時間で試験に十分に準備させることができます。この問題集の的中率がとても高いですから、問題集に出るすべての問題と回答を覚える限り、C_THR87_2505認定試験に合格することができます。
SAP Certified Associate - Implementation Consultant - SAP SuccessFactors Variable Pay 認定 C_THR87_2505 試験問題 (Q35-Q40):質問 # 35
Your customer has added a new employee to their Employee History. Based on the employee's data, they are eligible for the bonus plan, but when the customer tries to manually add them to a worksheet, they receive an error that the employee is unable to be added because they are ineligible. What might have been missed?
  • A. Updating business goals
  • B. Reloading the goal weights file
  • C. Recalculating bonus data
  • D. Updating worksheets
質問 # 36
Your client wants to change the label on a field in the Assignment Details level of their worksheet. Where could you make the change? Note: There are 2 correct answers to this question.
  • A. Column Designer, Entry Level fields
  • B. Custom Views
  • C. Employee History background element
  • D. Column Designer, Assignment Level fields
正解:C、D
質問 # 37
You are implementing an Employee Central-integrated Variable Pay template. The employee has 3 assignment records pulled from Employee Central, each with start and end dates within the bonus period, resulting in NO gaps or overlaps. What is the impact of the 3 assignment records on the payout?
  • A. Each record is considered when the employee's bonus payout is calculated and the bonus is prorated based on the dates of each record.
  • B. The first record is considered when the employee's bonus payout is calculated and the bonus is increased by 3X the target.
  • C. Each record is considered when the employee's bonus payout is calculated and the bonus is increased by 3X the target.
  • D. The last record is considered when the employee's bonus payout is calculated and the bonus is increased by 3X the target.
質問 # 38
What feature allows employees to view their individual bonus results even if variable pay forms are still in progress?
  • A. Bonus forecast
  • B. Variable Pay individual view
  • C. Compensation profile
  • D. Bonus assignment letter
質問 # 39
What information should be entered into the varPayProgramName column of the employee history data file?
  • A. The background type ID
  • B. The background element name
  • C. The plan template name
  • D. The variable pay objective plan ID
質問 # 40
お客様はC_THR87_2505学習資料の無料アップデートを1年間楽しむことができるため、情報の急速な発展はC_THR87_2505試験問題の学習価値を侵害しません。メールでC_THR87_2505スタディファイルの更新を受け取ります。また、C_THR87_2505スタディファイルには、PDF、ソフト、およびAPPバージョンの3つの異なるバージョンがあります。一方、C_THR87_2505試験の質問でご連絡いただければ、最高の提案を提供します。
C_THR87_2505日本語試験対策: https://www.xhs1991.com/C_THR87_2505.html
P.S. Xhs1991がGoogle Driveで共有している無料かつ新しいC_THR87_2505ダンプ:https://drive.google.com/open?id=17H_-C619uutuK8PjBXIbrn2hONutFu8O
