[Hardware] Serial debug port is down
154
Hardware Serial debug port is down
Posted at 9/28/2022 20:55:43      View3551 | Replies4        Print      Only Author   [Copy Link] 1#
I try to use serial debug on Windows using this link:
https://wiki.t-firefly.com/en/iC ... e-serial-on-windows
I use recommended adapter CP2104 and recommended driver.
But it wont work, i see only garbage symbols in my terminal session.
There is only 128000 bits per second speed in all versions of driver for CP2104, no 1500000 recommended by FireFly. Also i tryed old version of driver but speed still 128 kbits.
It looks like this version of CP2104 adapter doesn't support 1.5 mbits speed.
Can i work with my icore-3568jq without serial debug port ? I mean firmware change/build/write to SOM.
Can you help me with this problem ?
Posted at 9/29/2022 14:35:03        Only Author  2#
The software should be able to input a baud rate of 1500000 from the keyboard.
https://mobaxterm.mobatek.net/
Yesthe debug port is not necessary.
Posted at 1/11/2026 12:37:36        Only Author  3#
Im so thankful for your article, it was really eye-catching. Unlock your promotion with free CRT-450 new study questions free exam materialscareer growth is waiting!
Posted at 2/7/2026 05:33:42        Only Author  4#
I learned so much from the articleit was truly valuable. Thanks to the New CPT test experience program, I secured a promotion and salary increase. Its available for free now. Wishing you all quick promotions!
Posted at 2/16/2026 19:47:39        Only Author  5#
Die Amazon DVA-C02 Zertifizierungsprfung ist eine der beliebten und wichtigen Prfung in der IT-Branche. Wir haben die besten Lernhilfe und den besten Online-Service. Wir bieten den IT-Fachleuten eine Abkrzung. Die online Tests zur Amazon DVA-C02 Zertifizierungsprfung von ITZert enthalten viele Prfungsinhalte und Antworten, die Sie wollen. Wenn Sie die Simulationsprfung von ITZert bestehen, dann finden Sie, dass ITZert bietet genau was, was Sie wollen und dass Sie sich gut auf die Amazon DVA-C02 Prfung vorbereiten können.
