ISACA - The Best CISA Exam Reviews
106
Posted at 2/19/2026 04:41:04      View:106 | Replies:2        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of LatestCram CISA dumps for free: https://drive.google.com/open?id=1ElE4Yjploy7vE1J_bXHdsQPmHffKPSQ0
Furthermore, after acquiring our Certified Information Systems Auditor CISA Exam Questions preparation material, you will receive free updates for 365 days. LatestCram provides up-to-date Certified Information Systems Auditor exam questions, latest test dumps demo and latest test experience will make you success in your career. And price is affordable.
The CISA certification exam is a comprehensive, four-hour test consisting of 150 multiple-choice questions that test candidates' knowledge in five domains of information systems auditing: 1) The process of auditing information systems, 2) Governance and management of IT, 3) Information systems acquisition, development and implementation, 4) Information systems operations, maintenance and support, and 5) Protection of information assets. Candidates must score at least 450 out of a possible 800 points to pass the exam and earn the CISA Certification.
ISACA CISA (Certified Information Systems Auditor) certification is a globally recognized credential awarded to individuals who demonstrate expertise in information systems auditing, control, and security. Certified Information Systems Auditor certification is designed to validate the knowledge and skills required to assess the security and control of complex enterprise systems, and to provide assurance that they are operating in accordance with established standards and best practices.
CISA Certification Training - CISA Passing Score FeedbackWe believe that the greatest value of CISA training guide lies in whether it can help candidates pass the examination, other problems are secondary. And at this point, our CISA study materials do very well. We can proudly tell you that the passing rate of our CISA Exam Questions is close to 100 %. That is to say, almost all the students who choose our products can finally pass the exam. What are you waiting for? Just rush to buy our CISA learning braindumps!
ISACA Certified Information Systems Auditor Sample Questions (Q279-Q284):NEW QUESTION # 279
Which are the two primary types of scanner used for protecting against Malware?
Malware mask/signatures and Heuristic Scanner
Active and passive Scanner
Behavioral Blockers and immunizer Scanner
None of the above
  • A. Active and passive Scanner
  • B. None of the above
  • C. Malware mask/signatures and Heuristic Scanner
  • D. Behavioral Blockers and immunizer Scanner
Explanation/Reference:
Scanners Look for sequences of bit called signature that are typical malware programs.
The two primary types of scanner are
1. Malware mask or Signatures - Anti-malware scanners check files, sectors and system memory for known and new (unknown to scanner) malware, on the basis of malware masks or signatures. Malware masks or signature are specific code strings that are recognized as belonging to malware. For polymorphic malware, the scanner sometimes has algorithms that check for all possible combinations of a signature that could exist in an infected file.
2. Heuristic Scanner - Analyzes the instructions in the code being scanned and decide on the basis of statistical probabilities whether it could contain malicious code. Heuristic scanning result could indicate that malware may be present, that is possibly infected. Heuristic scanner tend to generate a high level false positive errors (they indicate that malware may be present when, in fact, no malware is present) Scanner examines memory disk- boot sector, executables, data files, and command files for bit pattern that match a known malware. Scanners, therefore, need to be updated periodically to remain effective.
For CISA exam you should know below mentioned different kinds of malware Controls
A. Active Monitors - Active monitors interpret DOS and read-only memory (ROM) BIOS calls, looking for malware like actions. Active monitors can be problematic because they can not distinguish between a user request and a program or a malware request. As a result, users are asked to confirm actions, including formatting a disk or deleting a file or set of files.
B. Immunizers - Defend against malware by appending sections of themselves to files - sometime in the same way Malware append themselves. Immunizers continuously check a file for changes and report changes as possible malware behavior. Other type of Immunizers are focused to a specific malware and work by giving the malware the impression that the malware has already infected to the computer. This method is not always practical since it is not possible to immunize file against all known malware.
C. Behavior Blocker - Focus on detecting potential abnormal behavior such as writing to the boot sector or the master boot record, or making changes to executable files. Blockers can potentially detect malware at an early stage. Most hardware based anti-malware mechanism are based on this concept.
D. Integrity CRC checker- Compute a binary number on a known malware free program that is then stored in a database file. The number is called Cyclic Redundancy Check (CRC). On subsequent scans, when that program is called to execute, it checks for changes to the file as compare to the database and report possible infection if changes have occurred. A match means no infection; a mismatch means change in the program has occurred. A change in the program could mean malware within it. These scanners are effective in detecting infection; however, they can do so only after infection has occurred. Also, a CRC checker can only detect subsequent changes to files, because they assume files are malware free in the first place. Therefore, they are ineffective against new files that are malware infected and that are not recorded in the database. Integrity checker take advantage of the fact that executable programs and boot sectors do not change often, if at all.
The following were incorrect answers:
The other options presented are not a valid primary types of scanner.
The following reference(s) were/was used to create this question:
CISA review manual 2014 Page number 354 and 355
NEW QUESTION # 280
An IS auditor finds that firewalls are outdated and not supported by vendors. Which of the following should be the auditor's NEXT course of action?
  • A. Determine the risk of not replacing the firewall.
  • B. Report the mitigating controls.
  • C. Report the security posture of the organization.
  • D. Determine the value of the firewall.
NEW QUESTION # 281
An IS auditor finds that the cost of developing an application is now projected to significantly exceed the budget. Which of the following is the GREATEST risk to communicate to senior management?
  • A. Inability to achieve expected benefits
  • B. Noncompliance with project methodology
  • C. Increased staff turnover
  • D. Project abandonment
Section: Information System Acquisition, Development and Implementation
NEW QUESTION # 282
Which of the following would be MOST important for an IS auditor to verify when conducting a business continuity audit?
  • A. Human safety procedures are in place
  • B. Data backups are performed on a timely basis
  • C. insurance coverage is adequate and premiums are current
  • D. A recovery site is contracted for and available as needed
The most important element in any business continuity process is the protection of human life. This takes precedence over all other aspects of the plan.
NEW QUESTION # 283
Which of the following would be of GREATEST concern to an IS auditor reviewing backup and recovery controls?
  • A. Restores from backups are not periodically tested
  • B. Weekly and monthly backups are stored onsite
  • C. Backups are stored in an external hard drive
  • D. Backup procedures are not documented
NEW QUESTION # 284
Our goal is to increase customer's satisfaction and always put customers in the first place. As for us, the customer is God. We provide you with 24-hour online service for our CISA study tool. If you have any questions, please send us an e-mail. We will promptly provide feedback to you and we sincerely help you to solve the problem. Our specialists check daily to find whether there is an update on the CISA study tool. If there is an update system, we will automatically send it to you. Therefore, we can guarantee that our CISA Test Torrent has the latest knowledge and keep up with the pace of change. Many people are worried about electronic viruses of online shopping. But you don't have to worry about our products. Our CISA exam materials are absolutely safe and virus-free. If you encounter installation problems, we have professional staff to provide you with remote online guidance. We always put your needs in the first place.
CISA Certification Training: https://www.latestcram.com/CISA-exam-cram-questions.html
P.S. Free & New CISA dumps are available on Google Drive shared by LatestCram: https://drive.google.com/open?id=1ElE4Yjploy7vE1J_bXHdsQPmHffKPSQ0
Posted at 2/19/2026 12:21:53        Only Author  2#
The content is incredible, I don’t even have to think before liking it. Thanks to the Latest GES-C01 study questions ppt, I secured a promotion and a raise. Now it’s free for everyone. May your career growth be swift and smooth!
Posted at 3/8/2026 02:04:52        Only Author  3#
I gained immense value from that article. With the New PRINCE2Foundation test experience, I achieved a promotion and pay raise. Now, it’s free for everyone. Best of luck with your career progression!
