Power Connector Size?
15
Posted at 12/17/2014 16:53:31      View12192 | Replies20        Print      Only Author   [Copy Link] 1#
Im looking at getting a heavy duty power adapter here for overclocking and heavy stress testing
http://www.adafruit.com/products/658
What I want to know is does the board already have a 2.1mm plug or should i purchase the usb converter for the Power adapter?
http://www.adafruit.com/products/988
if this is in the wiki im sorry i missed it
Posted at 12/17/2014 17:12:23        Only Author  2#
From the pictures you can see the board has a female dc connector. But i do not know the size, i would like to know the size as well
Posted at 12/17/2014 17:45:40        Only Author  3#
The power interface on Firefly is DC4.0 standard.
Posted at 12/18/2014 00:29:13        Only Author  4#
Thanks,  but in mm?
Posted at 12/18/2014 02:46:26        Only Author  5#
It's not a standard 2.5/2.1mm DC socket (see my comment) ?so you will need the usb adapter.
Posted at 12/18/2014 03:14:33        Only Author  6#
Thanks again Jas :] alright i was hoping i didnt but its not a big deal
Want to try for 2.5ghz so need to make sure power isnt an issue
Posted at 12/18/2014 04:26:02        Only Author  7#
ECHOA:
just replaced mine with a 5v 3a supply and the plug I used was a 1.7mm X 4mm.? I wouldn't go past the 3amp. Couldn't find the usb type had to buy the one piece molded unit.
Posted at 12/18/2014 04:38:04        Only Author  8#
ECHOA:
just replaced mine with a 5v 3a supply and the plug I used was a 1.7mm X 4mm.? I wouldn't go past the 3amp. Couldn't find the usb type had to buy the one piece molded unit.I need a charger 5v 3a as well. Where can i buy a good one shipped to italy? I only saw usb chargers 5v 3a on aliexpress, but thy do not seem quite good fron feedback. So any suggestion? Can i buy one with 1.7mm x 4.4 mm, is it sure?
Posted at 12/18/2014 06:26:40        Only Author  9#
ECHOA:
i decided the 4amp one would be enough for my needs :] its cheaper too
any reason you wouldnt go beyond 3amp? as im aware the board will only pull what it needs so going beyond 3 would only mean more headroom.
http://www.adafruit.com/products/1466
Posted at 12/18/2014 08:49:07        Only Author  10#
Echoa:
The Firefly is internally protected at the dc plug with a 3 Amp fusible link. So if pull over 3 amps on the board you will be learning how to solder a new power plug on the board. Look at the schematics third page power supply upper right hand corner.
Return to List
123
