[General] 100% Pass Quiz Trustable CPT - NASM Certified Personal Trainer Exam Top Dumps
90
General 100% Pass Quiz Trustable CPT - NASM Certified Personal Trainer Exam Top Dumps
Posted at 2/14/2026 11:24:58      View130 | Replies0        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of ExamsReviews CPT dumps for free: https://drive.google.com/open?id=1mmPIcXMvM0oK-yHHxkJXql359L5jrTor
To get better condition of life, we all need impeccable credentials of different exams to prove individuals capacity. However, weak CPT practice materials may descend and impair your ability and flunk you in the real exam unfortunately. And the worst condition is all that work you have paid may go down the drain for those CPT question torrent lack commitments and resolves to help custCPTomers. Moreover, only need toCPT spend 20-30 is it enough for you to grasp whole content of CPT practice materials that you can pass the exam easily, this is simply unimaginable.
If you are planning to pass the CPT exam, you can choose our CPT practice materials as your learning material since our products are known as the most valid exam engine in the world, which will definitely be beneficial to your preparation for exams. There are many impressive advantages of our CPT Study Guide. And our CPT actual exam will be definitely conducive to realizing the dream of obtaining the certificate.
Free PDF Marvelous NASM - CPT - NASM Certified Personal Trainer Exam Top DumpsOur company is a professional exam dumps material providers, with occupying in this field for years, and we are quite familiar with compiling the CPT exam materialls. If you choose us, we will give you free update for one year after purchasing. Besides, the quality of CPT Exam Dumps is high, they contain both questions and answers, and you can practice first before seeing the answers. Choosing us means you choose to pass the exam successfully.
NASM Certified Personal Trainer Exam Sample Questions (Q31-Q36):NEW QUESTION # 31
A trainer is observing a client perform a deadlift. Which of the following cues should the trainer provide?
  • A. "Keep your spine neutral."
  • B. "Start with your back rounded and arch as you lift."
  • C. "Arch your back."
  • D. "Let your chest fall forward to round the spine."
For a deadlift (a hip#hinge pattern), NASM emphasizes maintaining trunk stability via isometric contraction of the core to protect the spine. The CPT7 Study Guide states that"Stabilizers... contract isometrically to stabilize the trunk and joints as the body moves", naming key LPHC stabilizers such as thetransversus abdominis, internal obliques, and multifidus(). Keeping aneutral spineallows these stabilizers to do their job while the hips and knees generate movement, rather than forcing the lumbar spine into excessive flexion or extension. The guide further explains the human movement system's need to"dampen (eccentrically), stabilize (isometrically), and then accelerate (concentrically)"- NASM'sIntegrated Performance Paradigm(). In a deadlift, you eccentrically load through the hips, maintain isometric trunk stability (neutral spine), and then concentrically extend the hips and knees to stand tall. Cues like"arch your back"or"round your spine"push the lumbar segments away from neutral, compromising the length#tension relationship of spinal tissues and shifting load to passive structures instead of the intended prime movers. By contrast,"Keep your spine neutral"aligns directly with NASM's coaching focus on proper stabilization and joint alignment:
synergists assist appropriately, stabilizers hold the trunk, and agonists at the hips extend - all while the spine remains braced and neutral for optimal safety and performance (; ).
NEW QUESTION # 32
Which of the following is an example of an objective assessment?
  • A. Overhead squat assessment
  • B. Lifestyle questionnaire
  • C. Medical history questionnaire
  • D. General health history questionnaire
An objective assessment involves measurable, observable data collected through tests or direct observation.
The NASM CPT7 Study Guide lists the overhead squat assessment (OHSA) as part of the movement assessments category under objective data collection.
Medical history questionnaires, lifestyle questionnaires, and general health history questionnaires are subjective assessments, relying on client self-reports. The OHSA objectively identifies movement compensations, joint alignment issues, and muscle imbalances, making it a direct and measurable fitness assessment.
NEW QUESTION # 33
A trainer is facilitating a client's goal-setting process. Which of the following goals set by the client should the trainer clarify?
  • A. "I want to be in better shape in 1 month."
  • B. "I want to be able to run a 5K in 1 month."
  • C. "I want to lose 8 pounds in 1 month."
  • D. "I want to make it to the gym three times a week for 1 month."
NASM uses the SMART goal framework-Specific, Measurable, Attainable, Realistic, Timely-to help clients set effective goals. The statement "I want to be in better shape in 1 month" is vague because "better shape" is not defined or measurable.
By contrast, the other goals: losing 8 pounds in 1 month (Option A), running a 5K in 1 month (Option B), and going to the gym three times a week for 1 month (Option C) are more specific and measurable. The trainer should clarify vague goals by asking probing questions to define what "better shape" means to the client (e.g., improved strength, endurance, weight loss). Therefore, the goal requiring clarification is Option D.
NEW QUESTION # 34
Which of the following is a movement of the scapula?
  • A. Pronation
  • B. Supination
  • C. Protraction
  • D. Extension
NEW QUESTION # 35
A client's head protrudes forward during a pulling assessment. Which of the following muscles may be underactive?
  • A. Sternocleidomastoid
  • B. Upper trapezius
  • C. Deep cervical flexors
  • D. Levator scapulae
In a pulling assessment, if a client's head protrudes forward, NASM identifies the deep cervical flexors as commonly underactive. This forward head posture often results from overactivity in muscles such as the upper trapezius, sternocleidomastoid, and levator scapulae, combined with underactivity in stabilizing muscles like the deep cervical flexors. Corrective strategies include activation exercises for the deep cervical flexors and stretching/inhibiting the overactive neck and shoulder muscles.
NEW QUESTION # 36
We aim to provide the best service on CPT exam questions for our customers, and we demand of ourselves and our after sale service staffs to the highest ethical standard, though our CPT study guide and compiling processes have been of the highest quality. We are deeply committed to meeting the needs of our customers, and we constantly focus on customer's satisfaction. We play an active role in making every customer in which we selling our CPT practice dumps a better place to live and work.
Test CPT Online: https://www.examsreviews.com/CPT-pass4sure-exam-review.html
The CPT dumps pdf are extremely superior for the preparation on the CPT exam, We will notify you once the exam is available in your ExamsReviews Test CPT Online Member's Area, NASM CPT Top Dumps The safer,easier way to help you pass IT exams , Popular products, I believe our CPT training online will be the highest value with competitive price comparing other providers, NASM CPT Top Dumps We believe our products will meet all demand of all customers.
Consider implementing these ideas on your next new project, CPT Study Guides and perhaps even go back to an older site and see if it could stand to be improved, By reframing the design context from a digital screen to our natural course CPT of actions, Siemens created an incredibly intuitive and wonderfully elegant car entry solution for Mercedes.
NASM CPT Exam | CPT Top Dumps - Help you Pass Test CPT Online OnceThe CPT dumps pdf are extremely superior for the preparation on the CPT exam, We will notify you once the exam is available in your ExamsReviews Member's Area.
The safer,easier way to help you pass IT exams , Popular products, I believe our CPT training online will be the highest value with competitive price comparing other providers.
P.S. Free 2026 NASM CPT dumps are available on Google Drive shared by ExamsReviews: https://drive.google.com/open?id=1mmPIcXMvM0oK-yHHxkJXql359L5jrTor
