[Linux] RK3588-RT-V1.1
15
Linux RK3588-RT-V1.1
Posted at 10/30/2025 11:04:00      View826 | Replies3        Print      Only Author   [Copy Link] 1#
  • Type: Self-Compiled Firmware
  • SDK Package Name: Buildroot Linux SDK
  • Last Commit: 0000-00-00 00:00:00
  • Modification Content: make menuconfig
  • Log: log.zip
I have setup full sdk on our ubuntu18 system. I able to compile provided standard buildroot config. When I am trying to customise buildroot config via /buildroot/make menuconfig
Than saving config and executing ./build.sh
to create custom buildroot I constantly getting errors below:
# merged configuration written to /workspace/proj/rk3588_sdk/
firefly_rk3588_SDK/buildroot/output/firefly_rk3588/.config.in (needs make)
BR2_DEFCONFIG='' KCONFIG_AUTOCONFIG=/workspace/
proj/rk3588_sdk/firefly_rk3588_SDK/buildroot/output/firefly_rk3588/build/buildroot-config/auto.conf KCONFIG_AUTOHEADER=/workspace/proj/rk3588_sdk/firefly_rk3588_SDK/buildroot/output/firefly_rk3588/build/buildroot-config/autoconf.h KCONFIG_TRISTATE=/workspace/proj/rk3588_sdk/firefly_rk3588_SDK/buildroot/output/firefly_rk3588/build/buildroot-config/tristate.config BR2_CONFIG=/workspace/proj/rk3588_sdk/firefly_rk3588_SDK/buildroot/output/firefly_rk3588/.config HOST_GCC_VERSION="7" BASE_DIR=/workspace/proj/rk3588_sdk/firefly_rk3588_SDK/buildroot/output/firefly_rk3588 SKIP_LEGACY= CUSTOM_KERNEL_VERSION="5.10" BR2_DEFCONFIG=/workspace/proj/rk3588_sdk/firefly_rk3588_SDK/buildroot/configs/firefly_rk3588_defconfig /workspace/proj/rk3588_sdk/firefly_rk3588_SDK/buildroot/output/firefly_rk3588/build/buildroot-config/conf --defconfig=/workspace/proj/rk3588_sdk/firefly_rk3588_SDK/buildroot/output/firefly_rk3588/.config.in Config.in
# configuration written to /workspace/proj/rk3588_sdk/
make: Leaving directory '/workspace/proj/rk3588_sdk/
firefly_rk3588_SDK/buildroot'
450c450
< BR2_TARGET_GENERIC_ISSUE="
Welcome to test RK3588 Buildroot"
Welcome to RK3588 Buildroot"
467c467
< BR2_TARGET_GENERIC_ROOT_
PASSWD="root"
PASSWD="firefly"
Found old config, override it? (y/n):Command exited with non-zero status 142
you take 0:11.35 to build builroot
ERROR: Running build_buildroot failed!
ERROR: exit code 142 from line 1378:
    /usr/bin/time -f "you take %E to build builroot" $COMMON_DIR/mk-buildroot.sh $RK_CFG_BUILDROOT $DST_DIR
root@57bea03ddf96:/workspace/
proj/rk3588_sdk/firefly_rk3588_SDK#
log.zip
539 Bytes, Down times: 0
Posted at 11/3/2025 12:26:26        Only Author  2#
Despite its strange premise, the terrifying game fnaf manages to terrify players. The free edition, however, limits you to just two nights of gameplay. That, however, is more than enough to make you jump.
Posted at 1/13/2026 14:07:54        Only Author  3#
``֪RȫʥƥγɤǤ褦ˤ뤿AP-222ǥɡƥȽዤYAP-222ԇYЙCĤǺĤȡQ򥵥ݩ`Ȥ륳`ξAP-222¤ꥭΥϡAP-222ԇYʂʹäՓĥե``֪R򘋺Bä״Bɤ``򤱤ˡ}Q뷽ͨƽyϤYȥ󥯤gθܽӤ˥󥯤Ǥޤ
Posted at 1/18/2026 02:26:01        Only Author  4#
This is truly a magnificent article, thank you for sharing. Free Valid D-PST-OE-23 test practice resourcesyour key to career advancement and salary growth!
