Arduino IDE increase Fireduino support and the solution of compile unsuccessful
15
Posted at 11/18/2016 17:23:11      View5396 | Replies4        Print      Only Author   [Copy Link] 1#
Question one
   Updated verison of the manager appear CRC doesn't match. File is corruptedError condititions as shown in the figure below:
Reason:
   This problem generally appear in using the manager of official development board to update the SDK an error has occurred when testing packages.
The solution:
   Before refresh,let's open the development board manager update package storage directory,the default directory path is:
C:\Users\XXX\AppData\Local\Arduino15\staging\packages(XXX represents the current user name,the user name is my)delete the following two files as shown in figure format,such asfireduino_sdk-x.x.x.tar.gzdocuments (update package)then once again to upgrade SDK.
Question two
   In the process of compilingappear :error compiling for board Fireduino .
Reason:
    Platform support package access errors.
The solution:
   According to the Arduino IDE installation method is different,from the following path to find the platform support package:
1.Fireduino official download decompression version:
arduino-1.6.8\portable\packages\Firefly\hardware\arm(arduino-1.6.8 is the folder after decompression)
2.Arduino official version IDE installation verison:
C:\Users\XXX\AppData\Local\Arduino15\packages\Firefly\hardware\arm
      Delete files that can not correspond with SDK version of the development board manager. As shown in the figure below,at present, the latest version is 1.3.0 ,should be retained,as shown in the figure below:
Posted at 1/11/2026 02:41:29        Only Author  2#
Im so thankful for your article, its truly eye-opening. About to face the Download NSE4_FGT_AD-7.6 pdf exam. Wish me all the best!
Posted at 1/13/2026 06:39:19        Only Author  3#
This article is truly magnificent, thank you so much for sharing. Here are the Exam 1Z0-1079-24 objectives test questions for freeyour ticket to career success!
Posted at 1/14/2026 10:27:26        Only Author  4#
Your article has left a significant mark on me, thank you for it. With PMI-RMP reliable exam registration, you get comprehensive material available for free to support you.
Posted at 3/9/2026 09:05:51        Only Author  5#
Im deeply impressed by your article, thank you for sharing it! Visual C_BCBTM_2502 cert test helped me land a promotion and salary increase. Now, Im giving it to you for free!
