Working with UART0
18
Working with UART0
Posted at 12/22/2016 03:42:39      View4586 | Replies8        Print      Only Author   [Copy Link] 1#
Hi i want to use UART0 on FirePrime evb and I've followed everything in homepage at "Using UART"But i was not able to recieve data from PC to board it just gets two bit and then serial port doesnt work any more
it is while i can send data from board to PC without any problem.
How can I fix this?
Please help me
Thank you for your support
super moderator
Rank: 8Rank: 8
Posted at 12/22/2016 10:41:04        Only Author  2#
hi
is there any problem in your uart wire ? connect the TX to RX ,then check whether it is ok in your PC.
Posted at 12/24/2016 02:43:06        Only Author  3#
yes my pc is OK
I can send and recieve data even connect to debug port
But im not able to send data to port using uart0
after two first character it stops working some times after sending first charachter!
super moderator
Rank: 8Rank: 8
Posted at 12/24/2016 09:55:24        Only Author  4#
that is so strangehave you test it in both Ubuntu and Android ?
Posted at 12/25/2016 12:54:47        Only Author  5#
Ive just tried Ubuntu , and no luck
we need it to work on ubuntu
I had changed device tree files (.dtsi) in different ways and again no luck
super moderator
Rank: 8Rank: 8
Posted at 12/26/2016 14:17:07        Only Author  6#
have you disabled the blue tooth in the dts?
Posted at 12/26/2016 17:25:56        Only Author  7#
yes I had disabled it in rk3128-fireprime.dts file
and enabled uart0 node
For now i've given up fireprime evb as i dont have enough time to work on it
besides it has just one uart available while i need at least 2 uart ports
I think I would work with RK3288-Reload
Thanks for your support bro
Posted at 1/21/2026 06:21:04        Only Author  8#
This article is fantastic, thank you for sharing this insight. AZ-140 Exam Tests offers free, detailed content, hoping it benefits your studies.
Posted at 2/19/2026 12:40:37        Only Author  9#
Im left in awe by your article, thank you for sharing this treasure! The detailed content in New PRINCE2Practitioner test practice is free and available to help in your academic journey.
