New Topic
Fan connection
7
Fan connection
Posted at 3/27/2017 07:40:53      View5718 | Replies12        Print      Only Author   [Copy Link] 1#
Hi,
I noticed in my package for Firefly-RK3399 Plus, it also has a fan with this. Does this have to be connected? I see videos and screenshots without this fan used. Would the CPU get too hot without this? What if always running at max 100% on CPU?
Also the short cables connecting this fan blocks the way for one of the mipi ports closest to the fan.
Separate, how do you connect USB to UART Module to this board?
super moderator
Rank: 8Rank: 8
Posted at 3/27/2017 10:25:40        Only Author  2#
Hi
Hi ,the rk3399 have a over-temperature protection,when the cpu is too hot,the rk3399 will run slower,
so if always running  100%, we suggest you to connect the fan,
the UART debug :
http://wiki.t-firefly.com/index. ... 399/Serial_debug/en
Posted at 3/28/2017 02:56:45        Only Author  3#
Is there any way to have the fan only spin up when needed?  It's quite a loud fan, and it clearly isn't needed most of the time, but it seems to be running at full speed all of the time on Linux.
super moderator
Rank: 8Rank: 8
Posted at 3/28/2017 09:24:06        Only Author  4#
Yesthere is a  guy to made  it work:
http://developer.t-firefly.com/f ... hlight=%B7%E7%C9%C8
Posted at 4/1/2017 02:50:39        Only Author  5#
So there is no way to vary the speed of the fan via the on-board 3-pin controller?  Is this due to a lack of kernel support or a hardware limitation?
super moderator
Rank: 8Rank: 8
Posted at 4/5/2017 10:23:25        Only Author  6#
hardware limitation
Posted at 1/10/2026 09:48:46        Only Author  7#
After reading this article, I have a more thorough understanding of the related topics. Improve your IT abilitiesfree SCS-C02 valid test objectives now available! Good luck!
Posted at 1/22/2026 04:33:32        Only Author  8#
Thank you for sharing your article, its been truly enlightening. C-ARCIG-2508 latest exam dumps demo helped me secure a promotion and salary boost, and today, Im making it available for free!
Posted at 1/30/2026 16:18:23        Only Author  9#
The article provided me with so much to ponder. The C-S4CPB-2508 reliable exam dumps free helped me achieve a promotion and salary hike. Now, its free for everyone. Best of luck with your professional growth!
Posted at 2/1/2026 21:48:01        Only Author  10#
It was such an inspiring and educational read. Upgrade your IT knowledge with free Valid D-PE-FN-01 exam bootcamp materials. Wishing you all the best!
Return to List
12
