[Fireprime] OTA is possible?
33
Posted at 4/11/2017 08:08:47      View4325 | Replies7        Print      Only Author   [Copy Link] 1#
Hi,
I'm now using 3128 Lollipop 5.1 version.
I want to use OTA to upgrade Android system parts.
I followed your documenet to produce OTA packages.
But I have got  compile errors.
make clean
make -j4
make otapackage
I got errors.
I need help to fix thses errors.
Thank you in advance.
host Executable:fs_config(out/host/linux-x86/obj32/EXECUTABLES/fs_config_intermediates/fs_config)
Installut/host/linux-x86/bin/fs_config
No RK Loader forTARGET_DEVICE rk312x to otapackage
package addresource.img to BOOT and RECOVERY
No uboot foruboot/uboot.img to otapackage
No trust foruboot/trust.img to otapackage
No charge foruboot/charge.img to otapackage
No parameter forTARGET_DEVICE rk312x to otapackage
Package target filesut/target/product/rk312x/obj/PACKAGING/target_files_intermediates/rk312x-target_files-eng.jsmoon.zip
building image fromtarget_files RECOVERY...
Traceback (mostrecent call last):
  File"./build/tools/releasetools/make_recovery_patch", line 68, in<module>
   main(sys.argv[1:])
  File"./build/tools/releasetools/make_recovery_patch", line 39, in main
   input_dir, "RECOVERY")
  File"/home/jsmoon/work/prj_wallpad/fireprime_emmc/build/tools/releasetools/common.py",line 419, in GetBootableImage
   info_dict)
  File"/home/jsmoon/work/prj_wallpad/fireprime_emmc/build/tools/releasetools/common.py",line 376, in BuildBootableImage
    p4= Run(sign_cmd)
  File"/home/jsmoon/work/prj_wallpad/fireprime_emmc/build/tools/releasetools/common.py",line 86, in Run
   return subprocess.Popen(args, **kwargs)
  File"/usr/lib/python2.7/subprocess.py", line 710, in __init__
   errread, errwrite)
  File"/usr/lib/python2.7/subprocess.py", line 1327, in _execute_child
   raise child_exception
OSError: [Errno 2] Nosuch file or directory
make: ***[out/target/product/rk312x/obj/PACKAGING/target_files_intermediates/rk312x-target_files-eng.jsmoon.zip]오류 1
#### make failed tobuild some targets (03:33 (mm:ss)) ####
super moderator
Rank: 8Rank: 8
Posted at 4/11/2017 10:07:53        Only Author  2#
do you have the latest sdk?
or try this patch:
projects / tvbox-51.git / commitdiff
? search:
re
summary | shortlog | log | commit | commitdiff | tree
raw | patch (parent: 37383c6)
Android->OTA:modify OTA complie issue
author  cjp <service@t-firefly.com>
Tue, 23 Feb 2016 08:27:39 +0000 (16:27 +0800)
committer       cjp <service@t-firefly.com>
device/rockchip/common/releasetools.py          patch | blob | history
diff --git a/device/rockchip/common/releasetools.py b/device/rockchip/common/releasetools.py
index 83e75b9..38399c8 100755 (executable)
--- a/device/rockchip/common/releasetools.py
+++ b/device/rockchip/common/releasetools.py
@@ -134,8 +134,8 @@ def IncrementalOTA_InstallEnd(info):
     InstallTrust(trust_target, info.target_zip, info)
   else:
     print "trust unchanged; skipping"
- try:
+  try:
     loader_uboot_target = info.target_zip.read("uboot.img")
   except KeyError:
     loader_uboot_target = None
Posted at 4/11/2017 15:49:21        Only Author  3#
I got solved!!
Thank you!
Posted at 1/10/2026 01:58:11        Only Author  4#
Through this article, my work thinking has significantly improved. Free GES-C01 exam book exam questionsyour key to career growth and a better salary!
Posted at 1/14/2026 20:17:24        Only Author  5#
Im grateful to have come across such a fantastic article. The rich resources in Exam SAFe-Practitioner certification cost are provided at no cost to enhance your understanding.
Posted at 1/24/2026 14:26:54        Only Author  6#
This article is simply breathtaking, thank you for sharing it with us! I used the New H19-619_V1.0 exam practice to get promoted and get a pay raise. Now its free to all. I hope you all get promoted soon!
Posted at 1/26/2026 19:19:18        Only Author  7#
This article is absolutely stunning, I appreciate you sharing it. The Latest exam camp 401 free exam papers are free for all! Best of luck to everyone!
Posted at 1/30/2026 05:24:49        Only Author  8#
This article is outstanding, thank you for letting us read it. Heres the Reliable MB-700 exam camp materials test material for free. Best of luck in your exams!
