Pega Lead System Architect 24 PEGACPLSA24V1 Dumps Questions
Posted at 11/20/2025 16:12:42
If you are aiming to become a Certified Pega Lead System Architect, the newest PEGACPLSA24V1 Dumps Questions from Certspots are one of the most reliable and updated preparation tools available. These dumps are carefully curated based on real exam structures and the latest version 24.2 objectives, helping you understand advanced Pega architecture, platform capabilities, and design best practices. Certspots Pega Lead System Architect 24 PEGACPLSA24V1 Dumps Questions give you the edge you need to confidently tackle the Pega Lead System Architecture exam and move closer to earning the elite Pega LSA certification.
About the Pega Lead System Architecture ExamThe Certified Pega Lead System Architect (CLSA) certification is the highest-level technical credential offered by Pega. It is designed specifically for experienced Certified Pega Senior System Architects (CSSA) with at least 36 months of professional experience in real-world Pega projects.
The Pega Lead System Architecture (Version 24.2) exam validates deep expertise in application design, system architecture, platform capabilities, integration, performance, security, and enterprise-level best practices. Passing this exam is the first major step in the CLSA process, followed by the Application Design and Application Build exams.
PEGACPLSA24V1 Exam InformationKey DetailsInformation
Exam CodePEGACPLSA24V1
Number of Questions60
Passing Score65%
Duration120 minutes
PrerequisitesCertified Pega Senior System Architect / LSA EligibilityExam Domains and Topics BreakdownBelow is a descriptive overview of the skills and knowledge areas evaluated in the PEGACPLSA24V1 exam.
🔹 Pega Platform Design (15%)This section assesses your ability to design enterprise-scale Pega solutions:
- Understand Center-out Business Architecture and its cross-enterprise importance.
- Identify when to leverage other Pega products alongside core applications.
- Knowledge of Multitenancy, High Availability, Hazelcast, and Container-based architecture.
- Use features like Pega Process Fabric, Process Mining, and Agile Workbench.
- Apply best practices in production deployment, pipelines, and modular rollout strategies.
🔹 Pega Platform Design — Extended (10%)This expands into modern platform features:
- Use App Studio, Prediction Studio, and Admin Studio for scalable development.
- Reuse configuration assets effectively.
- Apply UX fundamentals, Constellation UI, DX API, and landing page design.
- Implement Pega GenAI Suite, GenAI Blueprint, and workflow design features.
🔹 Application Design (15%)Covers core architectural principles:
- Analyze Microjourneys and design proper case structures.
- Follow Pega Express methodologies and design patterns.
- Apply SOLID principles in object-oriented rule design.
- Understand when to use specializations (rulesets, class, application).
- Implement Testing standards, scenario tests, and rule check-in approvals.
🔹 Application Design — Extended (15%)Focuses on orchestration and runtime behavior:
- Assign work efficiently and design routing strategies.
- Customize Get Next Work.
- Handle flow changes for in-flight cases and use problem flows.
- Design asynchronous processing with Job Schedules, Queue Processors, and advanced background processing.
- Understand Stream services, data flows, logs, alerts, and PDC analysis.
🔹 Data Model Design (10%)Ensures data-driven architecture:
- Understand data relationships, greenfield modeling, and extending existing models.
- Use Pega data pages and the Data Virtualization Layer.
- Apply dynamic class references, polymorphism, and industry foundation models.
- Manage data integrity and aggregated data design.
🔹 Reporting Design (10%)This portion tests analytical and reporting expertise:
- Select the correct reporting strategy for business requirements.
- Design performance-focused reports and use Search & Reporting Services.
- Troubleshoot report performance, tune database queries, and build complex SQL logic.
- Use associations, class joins, and sub-reports efficiently.
🔹 Security Design (15%)A critical section for enterprise-grade Pega architecture:
- Determine authentication and authorization models.
- Apply role-based vs. attribute-based access controls.
- Configure access groups, dependent roles, and session management.
- Use Security Alerts, Auditing, and the Rule Security Analyzer.
- Identify vulnerabilities and mitigate potential attacks following Pega best practices.
🔹 Interface Design (10%)Focuses on building reliable and scalable integrations:
- Follow best practices for API design, external service deployment, and API access control.
- Implement CRUD operations via APIs.
- Manage and externalize services while ensuring security and standardization.
Why Earn the Pega Lead System Architect Certification?Becoming a CLSA elevates your career in several ways:
- Positions you as a top-tier Pega expert capable of leading transformational enterprise projects.
- Enhances your architecture, decisioning, integration, and design capabilities.
- Opens doors to high-level Senior Architect, Lead Architect, and Solution Architect roles.
- Equips you with advanced skills in Pega Infinity, Constellation UI, GenAI features, and scalable deployment models.
Best Tips to Pass the PEGACPLSA24V1 Exam- Review the official Pega Academy course materials – Complete the Pega Lead System Architecture training module to ensure you understand core concepts.
- Practice with real PEGACPLSA24V1 dumps – Use Certspots' updated dumps questions to familiarize yourself with the exam format and question types.
- Gain hands-on experience – Work on real Pega projects to apply theoretical knowledge in practical scenarios, especially in areas like security, integration, and data modeling.
- Focus on weak areas – Identify topics where you need improvement and spend extra time studying those domains.
- Understand the exam blueprint – Study the percentage breakdown of each domain and allocate your preparation time accordingly.
- Join Pega community forums – Engage with other certification candidates and experienced architects to share insights and clarify doubts.
- Take practice tests – Simulate the exam environment with timed practice tests to build confidence and improve time management.
- Stay updated with Pega 24.2 features – Ensure you're familiar with the latest platform capabilities, including GenAI Suite, Constellation UI, and DX API.
Final ThoughtsThe PEGACPLSA24V1 Certified Pega Lead System Architect 24 exam is a comprehensive evaluation of your ability to architect enterprise-grade Pega applications. With wide coverage across platform design, data models, integrations, security, and GenAI enhancements, proper preparation is essential.
Using updated training resources—especially the latest PEGACPLSA24V1 Dumps Questions from Certspots—will help you build confidence and ensure you’re fully prepared to pass the exam on your first attempt.
