New Topic
Download Boot Fail
80
Download Boot Fail
Posted at 9/26/2017 11:48:42      View9458 | Replies10        Print      Only Author   [Copy Link] 1#
After downloading a bad bootloader I can not boot into loader mode anymore.
I have booted into maskrom mode but can't flash any bootloader. I am trying to flash MiniBootLoader.bin from Firefly-RK3399_Android7.1.1_170829.
Every time I get "Download Boot Fail".
Posted at 9/29/2017 08:41:01        Only Author  2#
What configs are you using and have you tried a different tool? Every time I compile linux from scratch or try to program something that's not a distribution image I have to short the pads and boot in maskrom to load. If you're okay with the whole android image maybe you could try it in maskrom and see what happens. You're only shorting the pads when you apply power and not continuous right?
Posted at 9/30/2017 02:04:29        Only Author  3#
Thank you for your response. I actually solved my problem.
~~TLDR: Use a USB2 linux port.~~ Read next post!
I had to short the pads on the back of the board to get into maskrom mode since loader mode wasn't working (obviously since I broke the bootloader).
I tried flashing the bootloader on windows using FactoryTool and AndroidTool but both returned the same "Download Boot Fail". Even tried reinstalling the drivers to no avail.
Next I tried my linux laptop. Here I always got "Failed to create comm object", no matter which linux tool I used, same result. I found posts online that suggested this was a SELinux error and attempted the solution they provided, but again, no luck/same result.
Finally I had the idea to try a linux machine with a USB2 port since I had read about problems with rkflashkit and USB3 ports. Tried it and it instantly worked just as it was supposed to.
Posted at 10/23/2017 01:22:27        Only Author  4#
Finally discovered the source of my problem, I have tlp installed so auto suspend USB was enabled. It seems none of the tools support this, you will need to disable auto suspend USB power saving feature on your computer to get it to work.
Posted at 12/8/2017 04:04:08        Only Author  5#
Fallen Posted at 10/23/2017 01:22
Finally discovered the source of my problem, I have tlp installed so auto suspend USB was enabled. I ...
Thanks Fallen, i had a similar problem where my board is showing MASKROM MODE when connected to my Windows computer through the android tool. I tried everything to flash a new firmware, nothing is working. Please, what is the best computer to use when programming codes to these mini computer (rk3399 board). And also, what are the steps to take to re-install OS into the board. thanks.
Posted at 12/21/2017 15:22:19        Only Author  6#
It's any preconceived view that engaged and getting married is pricey. The largest expense may very well be the venue that may cost a group fixed everyday rate. You may well be surprised to listen to that haggling with the price tag on the place        universitywedding
In order to build an outstanding income from learning to be a wedding professional photographer, you usually do not simply be regarded a blessed photographer or be described as a master of one's camera. You must also find approaches to demonstrate in which to other folks.        supportwedding
One of the very most important selections for wedding party couples that are interested inside preserving the particular memories of these wedding day is always to hire a specialist wedding professional photographer. But it really is quite typical for your groom and bride to prioritize about all the things except that will be their particular wedding professional photographer.        studentwedding
Everything different comes initial, the outfit and tux, the particular bouquet, the particular reception. It really is at their particular bottom with the list that will be inside charged with the wedding images.        momswedding
Utilizing being married photographer is vital for anyone that is enthusiastic about preserving memories of these special evening. While extremely common for the groom and bride to concern yourself with various areas of their wedding including the flowers        knowwedding
Some folks simply think that they can just pick a wedding photographer and possess their images taken. Sometimes, the groom and bride may decide undertake a family member or even a close friend end up being the official wedding party photographer for special evening.        howwedding
Such aspects as professionalism and trust, experience and the opportunity to provide photo services in several formats are only some great things about obtaining a specialist wedding professional photographer.        answerwedding
Do you understand how several universal laws you can find? Or where did they work? They may be an old and honest guide to be able to living spiritually, as you will discover if you keep reading...        lawshowcase
What will be law regarding attraction? This question has been doing air the past decade considering that the theory with this law started to be public following your release with the book "The Secret". In this post the legislation of attraction continues to be mentioned inside details        lawextreme
Everything concerning this universe is a lot more intelligent as compared to we offer credit regarding; it is a real dazzling coherence in which run our own lives. We have been here to be able to mould the particular energies directly into matter and also create and also share Satisfied Living.        lawcountry
The universe comprises of distinct regulations and rules that rule our life style. Both accomplishment and disappointment are inside your control. Despite your overall condition, it is possible to make an improvement in an individual life and commence attracting far better things through the use of these regulations...        lawbucket
California is known as to have a number of the strictest firearm control laws in the united states with roughly 950 weapon laws currently in place. Supporters regarding stricter firearm laws argue why these laws are necessary to control crime        lawadventure
Nearly all finance careers require you to be very good with figures and know about basic organization statistics. Let's examine some in the lucrative fiscal education possibilities.        enterprise finance
Equity financing means the actual, own cash and financing. Usually smaller scale business including partnerships along with sole proprietorships are generally operated by simply their seller trough their unique finance. Joint investment companies operate judging by equity stocks        anywhere finance
High technology won't refer to your class involving technology because many technology are actually considered modern day at one particular point, before staying considered minimal tech as well as obsolete after some time.        glam technology
Information technological innovation generally is the term for all varieties of technology employed in the design, storage, exchange and by using data, conversation along with all multi-media varieties of communication. Using computer technological innovation constantly modifying        get your technology
An explanation simply of 2G along with 3G Technological innovation and precisely what they mean in your case these days. You will spot how 3G Telephones offer amazing features which include photo-editing, movie reports and virtual reality.        fake technology
There are actually great advancements inside technology sector over prior few ages. Consumers who've been alive to the past forty five years have witnessed what ended up being once deemed impossible are so prevalent these are taken for granted.        naughty technology
In 1997 Mr. Clayton Mirielle. Christensen (A new Harvard Organization School Tutor) introduces a whole new term "Disruptive Technology". He in addition describes that will displaces a proven technology.        a mateur technology
In the past, cooling majority solids including sugar, fertilizer, substances, plastics, dried up biosolids, vitamins, and all kinds of other types involving grains, crystals along with bulk powders with all the traditional technologies won't guarantee good quality final solutions.        that technology
Introduction involving new along with advanced engineering have brought a terrific revolution inside digital entire world. The technological innovation of portable comes underneath such wonderful technologies. The application of mobiles isn't more tied to the deliverance involving personal mail messages.        my best technology
The train of technological innovation transfer could greatly benefit a corporation. What can be technology shift? Technology transfer will be the sharing involving technology between 2 or more organizations.        find a technology
You are not able to escape or not use or the application of technology. Should you be not personally with it a different option . cell mobile phone, or computer system, technology is obviously touching and linked with your every day activities.        saver technology
Small businesses should be in tune while using proper, current technology. Whenever they are employing old, dated technology as well as broken devices, then what you are doing more injury than good plus your business are affected therefore.        professor technology
Online customers who know the product or service that they need to buy along with want to view the ideal competitive prices be aware that the easiest and quite a few reliable approach to do his or her online shopping is to use the service of an good comparability shopping internet site.        quiet shopping
Are you creating wealth with your current Etsy Look? Are you looking for ways to increase your current Etsy Income? Are you considering getting additional exposure for ones Etsy Look?        project shopping
Ever thought about why there exists never every day in occasion when places are unfilled? Deeper analysis will disclose that a number of customers who will be well known using some shopping outlets for two main main motives: They often want to maintain up with the most up-to-date fashion tendencies        million dollar shopping
It occurs as zero great surprise that this shopping behaviors of mount owners get changed rapidly in the past. This transfer has generally been because of the net. Increasing numbers of online tack shops get popped way up        get my shopping
There are nevertheless many shoppers who want to see along with feel products directly before handing their salary over. Each getting option has a unique positives and negatives and these might be of interest and realized before searching.        genius shopping
Your vehicle could possibly be of your most crucial investments. Selecting the best automotive search for repairs along with maintenance is important to keeping your car running in its optimum performance. One shop will not be appropriate for every single type involving automobile        chase shopping
Posted at 1/12/2026 22:46:24        Only Author  7#
This article is truly an outstanding work, and Ive benefited greatly from it. Using this CIS-HAM reliable exam collection sheet, I earned a promotion and raise. Now, its free for everyone. Best of luck in your career growth!
Posted at 1/15/2026 03:40:05        Only Author  8#
Your article was truly inspiring, thank you for sharing it with me. Get your hands on the free CIPT valid mock exam exam questions. Wishing you the best of luck!
Posted at 1/22/2026 14:18:08        Only Author  9#
Thank you for sharing this article, it's incredibly motivating! Im about to take the free HPE6-A86 Brain dumps exam. Wish me good fortune!
Posted at 2/18/2026 04:16:32        Only Author  10#
우리 Itexamdump에서는 최고이자 최신의VMware 인증3V0-22.25덤프자료를 제공 함으로 여러분을 도와VMware 인증3V0-22.25인증자격증을 쉽게 취득할 수 있게 해드립니다.만약 아직도VMware 인증3V0-22.25시험패스를 위하여 고군분투하고 있다면 바로 우리 Itexamdump를 선택함으로 여러분의 고민을 날려버릴수 있습니다.
Return to List
12
