Which camera is working as a front camera(by default) in firefly rk3399??
240
Posted at 1/31/2018 13:59:37      View5182 | Replies4        Print      Only Author   [Copy Link] 1#
Hi,
I am working on an android application which requires to have an access of front camera only.But I am not sure which camera(USB or MIPI CSI) is working as a front camera(by default) in firefly rk3399.And if we have to make any changes in the kernel to make it happen then, what they should be?
Posted at 1/31/2018 16:32:55        Only Author  2#
modify cam_board.xml 'SensorFacing' parameter.
Posted at 1/31/2018 18:13:47        Only Author  3#
leungɭ Posted at 1/31/2018 16:32
Thank you. I have found the file but will it work for USB camera or this is for MIPI CSI camera.
Posted at 2/1/2018 09:32:35        Only Author  4#
KrunalShah Posted at 1/31/2018 18:13
Is mipi, usb need to search code of the hardware/rockchip/camera/CameraHal/
key word "facing"
Posted at 1/22/2026 11:19:45        Only Author  5#
인재가 넘치는 IT업계에서 자기의 자리를 지켜나가려면 학력보다 능력이 더욱 중요합니다.고객님의 능력을 증명해주는 수단은 국제적으로 승인받은 IT인증자격증이 아니겠습니까? Google인증 Google-Workspace-Administrator시험이 어렵다고 하여 두려워 하지 마세요. IT자격증을 취득하려는 분들의 곁에는Fast2test가 있습니다. Fast2test의Google인증 Google-Workspace-Administrator시험준비를 하시고 시험패스하여 자격증을 취득하세요. 국제승인 자격증이라 고객님의 경쟁율을 업그레이드 시켜드립니다.
