Inconsistent boots
42
Inconsistent boots
Posted at 12/24/2014 02:48:41      View6108 | Replies8        Print      Only Author   [Copy Link] 1#
After powering down the device in Android or Ubuntu I notice the next set of power ups (using the PWRKEY) result in failed boots as shown below:
  1. U-Boot 2014.10-RK3288-02 (Dec 19 2014 - 19:50:49)
  2. CPU: rk3288
  3. CPU's clock information:
  4.     arm pll = 600000000HZ
  5.     periph pll = 300000000HZ
  6.     ddr pll = 200000000HZ
  7.     codec pll = 594000000HZ
  8. Board:  Rockchip platform Board
  9. DRAM:  Found dram banks:1
  10. Adding bank:0000000000000000(0000000080000000)
  11. 128 MiB
  12. DDR Version 1.00 20141007
  13. In
  14. Channel a: DDR3 200MHz
  15. Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=1024MB
  16. Channel b: DDR3 200MHz
  17. Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=1024MB
  18. DDR Version 1.00 20141007
  19. In
  20. Channel a: DDR3 200MHz
  21. Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=1024MB
  22. Channel b: DDR3 200MHz
  23. Bus Width=32 Col=10 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=1024MB
  24. Memory OK
  25. Memory OK
  26. OUT
Copy the code
After a number of random attempts the board does finally boot.
Posted at 12/24/2014 15:25:35        Only Author  2#
Please try a long press of PWR button (>3s) to see if the randomness will go away.
Posted at 12/25/2014 00:25:17        Only Author  3#
That seems to work.?
Another have question, what the maximum voltage the ADC input pins can take?
Posted at 12/26/2014 16:19:03        Only Author  4#
The maximum voltage the ADC input pins can take is 1.8V .
Posted at 1/10/2026 07:53:47        Only Author  5#
This is amazing content, Im giving it a like. The CIS-SM reliable exam price helped me get promoted and earn a raise, and now its open for free. Wishing you all rapid career growth!
Posted at 1/11/2026 01:01:39        Only Author  6#
Scaled Agile SAFe-ASE JCCǺܶITʿġScaled Agile SAFe-ASE JCԇǂzITI֪RͽJCԇͨ^ԇҪSIT֪Rͽ򞡣@N֪RһҪMĕrg;VCESoftǂ܎㹝srg;ľWվܿЧ؎aScaled Agile SAFe-ASE JCԇP֪R㌦VCESoftdȤھWMdVCESoftṩIJPScaled Agile SAFe-ASE JCԇľ}ʹLԇ
restricted members
Posted at 1/12/2026 08:49:51        Only Author  7#
ҪSAPC-TS4FI-2023JԇVCESoftC-TS4FI-2023}õĜʂ乤ߡ@YϿԎpͨ^ԇ@һurܸߵYϣͲٓĿԇˡ@}ԽQڜʂ俼ԇrһy}ُIVCESoftC-TS4FI-2023}֮ǰ߀dMĿ}ӱԇá@ͿԼД@YDzmԼ
Posted at 1/17/2026 02:45:32        Only Author  8#
Im thoroughly impressed, this deserves an instant like. Good luck! Here are the AZ-305 latest study guide ppt materials shared for free.
Posted at 1/23/2026 23:04:29        Only Author  9#
Your article is exceptional, thank you for sharing it with us! Free 250-589 reliable exam camp sheet test materialsthe essential resource for your promotion and salary increase!
