[General] Firefly-RK3288 and 7.85-Inches EDP Display Module not working
13
General Firefly-RK3288 and 7.85-Inches EDP Display Module not working
Posted at 5/17/2018 14:40:09      View7003 | Replies8        Print      Only Author   [Copy Link] 1#
I have connected the Firefly-RK3288 board and 7.85-Inches EDP Display Module as desribed here:http://en.t-firefly.com/doc/product/info/487.html. I got the latest sources from the firenow-lollipop repository (bitbucket, branch Firefly-RK3288) and did the patch for the display manually. The touch is working but i have no video output (only HDMI). Has anyone got this working?
Posted at 5/18/2018 20:08:39        Only Author  2#
After applying changes to the dts files, i get the following boot log. I woder why i get the 'Aux Transaction fail!' error.
DDR Version 1.00 20160530
In
Channel a: DDR3 200MHz
Bus Width=32 Col=10 Bank=8 Row=15/15 CS=2 Die Bus-Width=16 Size=2048MB
Channel b: DDR3 200MHz
Memory OK
Memory OK
OUT
U-Boot 2014.10-RK3288-10 (Oct 08 2016 - 15:45:52)
CPU: rk3288
cpu version = 0
CPU's clock information:
    arm pll = 600000000HZ
    periph pll = 297000000HZ
    ddr pll = 200000000HZ
    codec pll = 384000000HZ
Board:  Rockchip platform Board
DRAM:  Found dram banks: 1
Adding bank:0000000000000000(0000000100000000)
128 MiB
GIC CPU mask = 0x00000001
SdmmcInit = 0 400
SdmmcInit = 2 0
storage init OK!
Using default environment
GetParam
Load FDT from resource image.
power key: bank-0 pin-5
pmic:act8846
can't find dts node for pwm1
DCDC vdd_logic has been used, pwm regulator not init it.
Can't find dts node for fuel guage cw201x
SecureBootEn = 0, SecureBootLock = 0
#Boot ver: 2016-10-08#2.30
empty serial no.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
read logo on state from dts [1]
can't find power_ctr node for lcdc0
pll_src = 0, dclk_hz = 205000000, dclk_div = 2
edp pll locked
hw lt err:1
link train failed!
unable to config video
no fuel gauge found
Hit any key to stop autoboot:  0
load fdt from resouce.
ERROR: [get_entry_ram]: Cannot find logo_kernel.bmp!
Secure Boot state: 0
kernel   @ 0x02000000 (0x006a72a8)
ramdisk  @ 0x05bf0000 (0x001464a4)
bootrk: do_bootm_linux...
   Loading Device Tree to 05600000, end 0561c6d4 ... OK
Add bank:0000000000000000, 00000000fe000000
Starting kernel ...
Posted at 11/13/2024 18:54:05        Only Author  3#
Indulge in timeless elegance with ECS Khussa for women. Discover exquisite craftsmanship and traditional designs online. Step into cultural heritage and style with every stride. Explore our collection now!
Posted at 11/13/2024 21:04:18        Only Author  4#
Cloud Nexus Lab offers expert NetSuite Licensing solutions, including seamless implementation, consulting, and ongoing support. Our team helps businesses optimize their NetSuite experience with tailored solutions, ensuring efficient licensing management and smooth integrations. Get trusted guidance every step of the way.
Posted at 11/14/2024 16:46:16        Only Author  5#
Discover Kanwal Malik designer dresses in the UK with Qamaash. Our curated collection features stunning, intricately crafted gowns that blend elegance with modern culture. Elevate your style with exclusive designs that are perfect for weddings and special occasions.
Posted at 11/14/2024 17:21:51        Only Author  6#
google baseball is a delightful and engaging offline game where players swing at speedy pitches, striving for high scores with perfect timing and accuracy in a charming, retro-style setting.
Posted at 9/30/2025 12:57:20        Only Author  7#
I had a similar experience when I was setting up my Firefly-RK3288 board a while ago. Troubleshooting the display connection took some time, but discussing with others on platforms dedicated to tech hobbies really helped. Speaking of sharing knowledge, if you enjoy basketball or want a fun break, I recommend checking out the Basketball Stars platform. Its a great way to relax and connect with others.
Posted at 1/28/2026 17:40:44        Only Author  8#
Pass4Tes가 제공하는 제품을 사용함으로 여러분은 IT업계하이클래스와 멀지 않았습니다. Pass4Tes 가 제공하는 인증시험덤프는 여러분을SAP인증C_ABAPD_2507시험을 안전하게 통과는 물론 관연전업지식장악에도 많은 도움이 되며 또한 우리는 일년무료 업뎃서비스를 제공합니다.
Posted at 3/16/2026 16:02:27        Only Author  9#
Birdsoles is a Pakistan-based footwear brand that specializes in comfortable clogs , slides, and sandals made from EVA foam. The products are available for purchase online through their official website, which offers nationwide shipping within Pakistan.
