rockchip_drv_video.so
46
Posted at 5/20/2018 14:32:39      View6525 | Replies2        Print      Only Author   [Copy Link] 1#
I want to test the video hardware codecs on the RK3399 to transcode video.
I noticed that ffmpeg is apparently able to access hardware for h.264 and h.265v video.
I installed vainfo and vdpauinfo:
        sudo apt-get install vainfo
        sudo apt-get install vdpauinfo
First I tried running vainfo:
        [firefly@firefly] ~ 1182: sudo vainfo
        error: XDG_RUNTIME_DIR not set in the environment.
        libva info: VA-API version 0.39.0
        libva info: va_getDriverName() returns 0
        libva info: Trying to open /usr/lib/aarch64-linux-gnu/dri/rockchip_drv_video.so
        libva info: va_openDriver() returns -1
        vaInitialize failed with error code -1 (unknown libva error),exit
Aside from XDR_RUNTIME_DIR not being set the command reports an error regarding the rockchip video driver - as it turns out one isn't installed:
        [firefly@firefly] ~ 1183: ls /usr/lib/aarch64-linux-gnu/dri/
        ./   dummy_drv_video.so    r600_drv_video.so
        ../  nouveau_drv_video.so  radeonsi_drv_video.so
A similar library error is reported missing in action when I attempt to use vdpauinfo:
        [firefly@firefly] ~cv 1184: sudo vdpauinfo
        display: :0.0   screen: 0
        Failed to open VDPAU backend libvdpau_rockchip.so: cannot open shared object file: No such file or directory
        Error creating VDPAU device: 1
It's obvious that vainfo knows it's a rockchip device, so that's a good sign. I'm going to look around and see if I can locate a package with the drivers, but I'm wondering if this is the correct approach.
Has anyone else managed to utilize ffmpeg to access the harware video codecs?
Posted at 2/4/2026 10:39:46        Only Author  2#
I deeply appreciate your article, it was truly unforgettable. Free New C_S4CPR_2508 exam duration resourcesyour key to climbing the career ladder!
Posted at 4/20/2026 03:00:38        Only Author  3#
˲׌zڣ҂ԓMץסһи׃ęCˆ᣿NewDumps WGUHealth-Fitness-and-WellnessԇӖYǎÿɹITʿṩӖYϣゃͨ^WGUHealth-Fitness-and-WellnessԇJC˲׌ɹcʧۣ֮soЄӰɡ
