[Linux] My Firefly-RK3288 device does not boot with kernel panic.
99
Linux My Firefly-RK3288 device does not boot with kernel panic.
Posted at 6/22/2018 09:05:38      View7639 | Replies6        Print      Only Author   [Copy Link] 1#
Hi,
I'm newbee and trying to build and flash the my linux images. I have followed to this two Rockchip document [Linux user guide] and [Boot option].
I succeeded in building images, but my RK3288 board does not boot.
This is my images.
  1. ~/linux/rockdev$ tree
  2. .
  3. boot.img -> /home/userName/linux/kernel/zboot.img
  4. MiniLoaderAll.bin -> /home/userName/linux/u-boot/rk3288_loader_v1.06.236.bin
  5. misc.img -> /home/userName/linux/device/rockchip/rk3288/rockdev/wipe_all-misc.img
  6. oem.img -> /home/userName/linux/device/rockchip/rk3288/rockdev/oem.img
  7. parameter.txt -> /home/userName/linux/device/rockchip/rk3288/rockdev/parameter.txt
  8. recovery.img -> /home/userName/linux/buildroot/output/rockchip_rk3288_recovery/images/recovery.img
  9. rootfs.img -> /home/userName/linux/buildroot/output/rockchip_rk3288/images/rootfs.ext4
  10. trust.img -> /home/userName/linux/u-boot/trust.img
  11. uboot.img -> /home/userName/linux/u-boot/uboot.img
  12. userdata.img -> /home/userName/linux/device/rockchip/rk3288/rockdev/userdata.img
Copy the code
and parameter.txt
  1. CMDLINE: mtdparts=rk29xxnand:0x00002000@0x00004000(uboot),0x00002000@0x00006000(trust),0x00002000@0x00008000(misc),0x00010000@0x0000a000(boot),0x00010000@0x0001a000(recovery),0x00010000@0x0002a000(backup),0x00020000@0x0003a000(oem),0x00700000@0x0005a000(rootfs),-@0x0075a000(userdata:grow)
Copy the code
This is my AndroidTool settings. Flash is succeeded.
It's Brinking underbar on Display, and shining OTG Green LED.
Please help someone. Thank you.
Posted at 6/23/2018 11:59:04        Only Author  2#
I edited the parameter.txt, but the same result.
  1. CMDLINE: mtdparts=rk29xxnand:0x00002000@0x00004000(uboot),0x00002000@0x00006000(trust),0x00010000@0x00008000(boot),0x00700000@0x00040000(rootfs)
Copy the code
Posted at 6/24/2018 11:22:02        Only Author  3#
ueue Posted at 6/23/2018 11:59
I tried logging by serial connector. It seems that kernel panic.
  1. [   10.641492] ---[ end Kernel panic - not syncing: No working init found.  Try passing init= option to kernel. See Linux Documentation/init.txt for guidance.
  2. [   36.308449] ------------[ cut here ]------------
  3. [   36.313071] WARNING: CPU: 2 PID: 1 at kernel/watchdog.c:352 watchdog_timer_fn+0x164/0x340()
  4. [   36.321404] Watchdog detected hard LOCKUP on cpu 3
  5. [   36.326018] Modules linked in:
  6. [   36.329264] CPU: 2 PID: 1 Comm: swapper/0 Not tainted 4.4.132 #1
  7. [   36.335262] Hardware name: Generic DT based system
  8. [   36.340057] [<c0110014>] (unwind_backtrace) from [<c010bcbc>] (show_stack+0x20/0x24)
  9. [   36.347790] [<c010bcbc>] (show_stack) from [<c040824c>] (dump_stack+0x84/0xa0)
  10. [   36.355003] [<c040824c>] (dump_stack) from [<c011d9ac>] (warn_slowpath_common+0x98/0xc4)
  11. [   36.363084] [<c011d9ac>] (warn_slowpath_common) from [<c011da18>] (warn_slowpath_fmt+0x40/0x48)
  12. [   36.371776] [<c011da18>] (warn_slowpath_fmt) from [<c01b201c>] (watchdog_timer_fn+0x164/0x340)
  13. [   36.380377] [<c01b201c>] (watchdog_timer_fn) from [<c01894d4>] (__hrtimer_run_queues+0x1bc/0x31c)
  14. [   36.389243] [<c01894d4>] (__hrtimer_run_queues) from [<c0189ca8>] (hrtimer_interrupt+0xac/0x1f8)
  15. [   36.398019] [<c0189ca8>] (hrtimer_interrupt) from [<c078aa14>] (arch_timer_handler_phys+0x38/0x48)
  16. [   36.406969] [<c078aa14>] (arch_timer_handler_phys) from [<c017a2ec>] (handle_percpu_devid_irq+0xd4/0x1a8)
  17. [   36.416523] [<c017a2ec>] (handle_percpu_devid_irq) from [<c0175bd0>] (generic_handle_irq+0x28/0x38)
  18. [   36.425563] [<c0175bd0>] (generic_handle_irq) from [<c0175f2c>] (__handle_domain_irq+0xb0/0xc4)
  19. [   36.434254] [<c0175f2c>] (__handle_domain_irq) from [<c0101474>] (gic_handle_irq+0x60/0xa4)
  20. [   36.442596] [<c0101474>] (gic_handle_irq) from [<c010c6d4>] (__irq_svc+0x54/0x70)
  21. [   36.450062] Exception stack(0xee941ec0 to 0xee941f08)
  22. [   36.455110] 1ec0: ee941f3c 00000000 fd640800 c10a2ac0 ee941f3c 00005dbf 00006400 000064c8
  23. [   36.463276] 1ee0: 00000033 c1054cd4 066665b0 ee941f1c ee941f20 ee941f10 c0406100 c010f3c4
  24. [   36.471439] 1f00: a0000013 ffffffff
  25. [   36.474931] [<c010c6d4>] (__irq_svc) from [<c010f3c4>] (arch_timer_read_counter_long+0x18/0x28)
  26. [   36.483622] [<c010f3c4>] (arch_timer_read_counter_long) from [<c0406100>] (read_current_timer+0x30/0x48)
  27. [   36.493093] [<c0406100>] (read_current_timer) from [<c0406150>] (__timer_delay+0x38/0x5c)
  28. [   36.501259] [<c0406150>] (__timer_delay) from [<c04061a0>] (__timer_const_udelay+0x2c/0x34)
  29. [   36.509602] [<c04061a0>] (__timer_const_udelay) from [<c01e9a5c>] (panic+0x1cc/0x200)
  30. [   36.517422] [<c01e9a5c>] (panic) from [<c0a95b60>] (kernel_init+0xe4/0x118)
  31. [   36.524380] [<c0a95b60>] (kernel_init) from [<c0107590>] (ret_from_fork+0x14/0x24)
  32. [   36.531939] ---[ end trace fafe7db505aa2fdd ]---
Copy the code
Does not rockchip official image support Firefly-RK3288?
Posted at 1/9/2026 12:14:18        Only Author  4#
This article has truly been inspiring, thanks for sharing! NSE5_FNC_AD_7.6 vce test simulator gives you a wealth of free content, created to assist you.
Posted at 1/11/2026 12:20:00        Only Author  5#
I am deeply inspired by this article, thanks for sharing! This Valid exam 1Z0-1085-25 sample questions helped me achieve career growth with a promotion and salary raise. Its free now for everyone. Wishing you success!
Posted at 1/13/2026 07:49:12        Only Author  6#
Wenn Sie sich zur Salesforce AP-226 Zertifizierungsprfung anmelden, sollen Sie sofort gute Lernmaterialien oder Prfungsunterlagen wählen, um sich gut auf die Prfung vorzubereiten. Denn die Salesforce AP-226 Zertifizierungsprfung ist eine schwierige Prfung und Sie mssen dafr ausreichende Vorbereitungen haben.
Posted at 1/26/2026 13:41:58        Only Author  7#
Im not hesitating; this content gets my like. The Latest ZDTA test sims questions are the key to successget them for free and unlock your promotion!
