Linux
can't mount network smb share
Posted at 8/4/2018 00:57:31
View6531
Replies6
I have two identical ROC-RK3328-CC's running Ubuntu. They both have external usb drives attached. These drives are successfully mounted and shared on the network, and visible to other devices on the LAN. I wish to mount the one ROC's network share on the other. I can mount ROC1's share successfully from a RPi on the LAN with the command:
sudo mount -t cifs -o username=firefly '\\192.168.1.173\EXTERNAL' /mnt/Firefly1
This works fine (of course, after previously creating the mount point on the Pi, responding to the password prompt, etc.; 'EXTERNAL' is the name of the share and 192.168.1.173 is the IP address of ROC1).
When I try to execute this same command from ROC2 (of course I created the mount point first) I get:
mount error: cifs filesystem not supported by the system
mount error(19): No such device
I had previously installed the packages on ROC2 (and ROC1) with:
sudo apt-get install samba-common smbclient samba-common-bin smbclient cifs-util
However, even after installing these packages (and rebooting, etc.) modprobe cifs gives:
modprobe: FATAL: Module cifs not found in directory /lib/modules/4.4.114
How can I mount one ROC's smb share on another? Thanks!
