[General] Technical briefing for Firefly-RK3399 Android8.1 Updates Firmware(2018/08/03)
385
super moderator
Rank: 8Rank: 8
General Technical briefing for Firefly-RK3399 Android8.1 Updates Firmware(2018/08/03)
Posted at 8/7/2018 11:23:16      View7879 | Replies3        Print      Only Author   [Copy Link] 1#
Firefly-RK3399 Android8.1 Neural Network Hardware Acceleration Firmware Released: video
GoogleDriverDownload
Update:1. Update AOSP android-8.1.0_r33
2. Fix mouse click problem
3. Optimize system and fix some bug.
4. Support mipi-csi ov13850
5. Support spdif output.
Pls erase the flash first , reboot the board and then flash image
Posted at 12/13/2018 20:56:06        Only Author  2#
Hi Firefly team
I having trouble to upgrade my RK3399 board.
the steps I did:
1) downloaded the last firmware available, that is Firefly-RK3399_Android8.1.0_HDMI_181023.img,
and the update tool v1.31 for android 8 ('ive also tried the v1.34).
2) rebooted into "loader" mode bu pressing power, and holding recovery button for 3 sec.
3) run "./upgrade_tool uf ../../Firefly-RK3399_Android8.1.0_HDMI_181023.img" as a super user
expected - flashed firmware
real - system pass "Test Device Start" and "Test Device Successful", and then halt at "Check Chip Start" for at least 30 minutes.
also upgrade_tool EF, hangs for a long time, bat has no effect.
What is the right way to update to the last firmware ?
Posted at 1/22/2019 20:25:22        Only Author  3#
OK, fount the trick
before you install, remove the old firmware with the OLD update_tool (the same used to install, update_tool 1.24 in my case)
after that you can install the new firmware with the new android 8 tool
Posted at 1/14/2026 15:41:01        Only Author  4#
Im grateful for your article, it truly made an impact on me. Sharing the Frenquent Data-Engineer-Associate update exam that got me my promotion and salary raiseits free for all today. Hope you all achieve your professional dreams!
